Old 04-19-2008, 09:00 AM   #1
gaylejoe's Avatar
2007 25' Safari FB SE
St. Hedwig , Texas
Bath Roof Vent Leaking
The Van Air 12 volt vent in the bath leaks when it rains. I have used the water hose and put water around the base on top of the trailer but it does not leak. When it rains, the water comes in through this vent. It doesn't matter whether the vent is raised or lowered. Any ideas where the water is entering the vent?
This is a 2003 Safari and is kept inside storage except when we bring it home to load for our trips.
Please feel free to call me at 210-860-6006.
gaylejoe is offline   Reply With Quote
Old 04-19-2008, 10:17 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
My trailer the top plastic cover on the vent was cracked. Also raise the vent and check from the outside. On mine there is a vertical metal rim around the fan opening with a 1/4 in drain hole at the lowest point. That hole was plugged with dirt and caused water to spill back int the ceiling.
That rim is to keep wind blown water from entering when the vent is opened but weith the hole being plugged and the plastic cover cracked it caused water to get in.
2004 Excursion 4x4
Old 04-20-2008, 07:22 PM   #3
gaylejoe's Avatar
St. Hedwig , Texas
Howie, I think that I cured my problem, I hope. There is a rubber insert on each side of the vent cover. I believe the water was entering this area. I took them out and re-sealed them with silicon. Did the water test and no water entered the trailer. I'm just hoping this may have cured my problem. I certainly appreciate the imput.
Old 04-20-2008, 07:47 PM   #4
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
IMHO, this may have been a better choice of sealant.
Name:	SOLAR PANELS; ROOF LEAK 021.jpg
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 05-06-2008, 05:21 AM   #5
kstampa's Avatar
2004 28' International CCD
tampa , Florida
Images: 35
geez i have the same leak probblem on both my pop ups (1 in shower and 1 in the bathroom). I hope my fix is as easy as that!
kstampa is offline   Reply With Quote
Old 05-06-2008, 06:40 AM   #6
vhord's Avatar
Images: 96
I stock that same caulk (PL Polurethane) in my hardware store but purchased some Vulkem from an online supplier. Both seem to be very much the same. Does anyone know how much difference there are in the two products? Since I can purchase the PL wholesale is the Vulkem worth 3-4 times the costs including freight?
vhord is offline   Reply With Quote
Old 05-06-2008, 02:33 PM   #7
Vulkem??
If Vulkem is that stuff that was smeared all over the roof of our AS, I'm
not sure what the chemical difference might be, but the PL sealant seems
to be a little more flexable (tough) when dry and was easy to use. Was up
on the roof for Spring get ready and still looks great. Only time will tell.
The black color was my only concern, does absorb more heat. But then
again that "white" Vulkem gets pretty crudy looking after awhile.
http://www.airforums.com/forums/f456...ent-35651.html
PFC
RLC
Old 05-07-2008, 06:36 AM   #8
vhord's Avatar
Images: 96
Polyurethane caulking
The PL caulking that I have is actually "PL Polyurethane Window, Door & Siding Sealant" (Ace stock #1050889) and it is the same color as the Vulkem that I purchased (gray). It says on the tube that it "is a premium comercial sealant for permanent, water and weather resistant exterior gaps and joints" and it states that it has a 50 year life and is permanently flexible.
Old 05-30-2008, 06:32 PM   #9
Interesting read. I guess this to be a common problem. I'm having same issues now also in my 2005 AS international.
Can't see anything obviously broken right now but I was not aware of the drain hole. Would anyone recommend removing the sealant and replacing it, or just apply new sealant on top of the old stuff? Is the roof strong enough for me to lie on it? Thanks.
goldwing70 is offline   Reply With Quote
Leaking Range vent chuman70 Roof Vents, Skylights & Fans 6 07-06-2007 07:58 AM
Leaking A/C roof gasket? ArtStream Furnaces, Heaters, Fireplaces & Air Conditioning 1 10-28-2006 11:30 AM
Leaking Vent-Tank re-fit LI Pets Waste Systems, Tanks & Totes 0 10-11-2006 07:18 PM
Safari roof still leaking Raptorrider2001 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 9 03-04-2003 11:32 AM
