Old 04-10-2010, 08:42 AM   #1
nevada , Nevada
astrodome removal
anyone know the trick of removing the astrodome? mine looks like everything is riveted, would like to take it down and refurbish it if I only knew how to remove the bugger.
wolfpack is offline   Reply With Quote
Old 04-10-2010, 09:35 AM   #2
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
The lifters are held in place by two prongs that come out of the vent frame. Stick a screwdriver in there and pry one of these prongs apart from the lifter and it will come right out. Once both ends of the Astrodome are loose, you can maneuver it around and bring it in through the vent opening. with the Astrodome off, you can service it and can access the top of the vent opening rim from inside the trailer while standing on a step stool.
Hope this helps. Good luck.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Astrodome Installation Whiteout1 Roof Vents, Skylights & Fans 5 01-12-2008 06:11 PM
Astrodome question? PensacolaJim Roof Vents, Skylights & Fans 5 01-05-2008 11:27 AM
Astrodome Replacement Cochese Roof Vents, Skylights & Fans 2 09-10-2007 02:05 PM
Been Kicked in the Astrodome Jeffrey Stoecker Roof Vents, Skylights & Fans 1 04-19-2006 08:31 PM
astrodome kenlmarc Roof Vents, Skylights & Fans 0 02-27-2003 12:09 PM
