Old 10-03-2007, 10:15 PM   #1
gparker's Avatar
1970 31' Sovereign
Denham Springs , Louisiana
anyone tried this vent cover?
These have been on ebay lately. Has anyone tried one? For the price, looks like you could afford to replace it fairly often if need be.
Greg
eBay Motors: RV Revcon Airstream vent lid fiberglass replacement NEW (item 190159441135 end time Oct-13-07 16:31:50 PDT)
Greg, Ashley, Olivia, and Jane Ashley
AIR # 13681
gparker is offline   Reply With Quote
Old 10-03-2007, 10:29 PM   #2
Fyrzowt's Avatar
West of Fort Worth , Texas
Images: 8
It said it was used in the "condition" description, but new in the title??? Also that there is no hardware included.
Fyrzowt is offline   Reply With Quote
Old 10-04-2007, 06:34 PM   #3
Don Boyd's Avatar
1971 27' Overlander
1970 25' Tradewind
1989 19' "B" Van Airstream 190
cromwell , Kentucky
I ordered one and got it a week or so ago. it is fiberglass and has no hardware or holes for harware. I think it should be alright. please note, this cover is not clear and some areas will appear dark as the sun shines on this cover. I bought mine because the others i saw were around three times the cost and this one will keep out the weather, something the original stopped doing a long time ago.
Don Boyd is offline   Reply With Quote
Old 05-05-2008, 08:07 PM   #4
Don Boyd's Avatar
1971 27' Overlander
1970 25' Tradewind
cromwell , Kentucky
Just as I promised
Here is a before picture of the old astrodome from the inside.
here is the new one from the inside.
here is the outside.
if you want a astrodome that keeps out the weather for a reasonable price, then this is the unit for you. if you are looking for a clear or tinted skylight, you need to buy one of the more expensive astrodome covers. good luck, Don
Old 05-11-2008, 01:56 PM   #5
Don Boyd's Avatar
1971 27' Overlander
1970 25' Tradewind
cromwell , Kentucky
Doesn't let much light in
I took these pictures at the lake this weekend to show how much light gets through the fiberglass. Here is what it looks like from te inside with all of the lights off and the curtains shut.
it was a little gloomy outside
the sky was overcast
Old 05-11-2008, 03:42 PM   #6
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
alternate skylight
Here is a flat alternative to buying a more expensive lid. It cost about $10 of material and took 30 mins. to build. I used Lexan corregated sheet stock 1/4 inch thick that has round lumens that run parallel to the trailer. The edging is made from one inch angle aluminum (you can use stock material from siding) clip bend the corners and pop rivet. The Lexan sheet is also held in with pop rivets. You need to use sealent as well as foam gasket for sealing to the opening to make sure it is waterproof. It certainly does not look stock but it is more durable and lets in the light. You could also use smoke Lexan, if you wanted a little less light.
ID:	60275   Click image for larger version
Astradome vent cover cookeville34 Roof Vents, Skylights & Fans 4 11-28-2006 05:42 PM
Vent Cover Color ? Janets Husband Roof Vents, Skylights & Fans 2 08-22-2004 02:14 PM
Need a New Refridgerator Vent Cover John and Anne Airstream Motorhome Forums 3 07-11-2004 07:41 AM
vent cover repair.... Chuck Windows & Screens 10 11-13-2002 12:05 PM
