Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Roof Vents, Skylights & Fans
Old 04-19-2010, 12:20 PM   #1
2007 25' Safari SS SE
Camarillo , California
Anyone tried the 'Xtreme Vent'?
We're thinking of replacing the little plastic roof waste vent on our 2007 Safari 25 with an Xtreme Vent that rotates and uses the venturi effect to keep the waste tanks aired out.
Has anyone tried one of these products?
Thanks.
Eckhart is offline   Reply With Quote
Old 04-19-2010, 02:32 PM   #2
1975 29' Ambassador
Reno , Nevada
I wonder about these things. Putting a negative pressure on the gray tanks will tend to purge the traps and purged traps will allow tank smell into the trailer. Putting a negative pressure on the black tank might also purge a trap if you have a sink that drains into it else it just tries to suck the layer of water you should have in the toilet through the toilet valve.
Fortunately, the chemical you need to keep your tanks in good shape is cheap and readily available. Dihydrogen monoxide (DHMO) is considered extremely dangerous by some but you have plenty with you (or should have because it helps your Airstream stability), and, as a universal solvent, will keep crud from building up in the tank if you apply enough to keep the waste covered.
Those venturi things do make good wind vanes, though.
Old 04-19-2010, 02:46 PM   #3
CanoeStream's Avatar
St. Cloud , Minnesota
The vents use a natural stack effect to do their job. RV parts are like fishing lures -- doesn't matter how much they catch fish as long as they catch you. Is this a cure for a non-problem?
5 meter Langford Nahanni
Old 04-19-2010, 06:57 PM   #4
Contributing Member
Pahaska's Avatar
Austin (Hays County) , Texas
No problem with evacuation traps ... not enough vacuum, even at highway speeds.
We notice that fewer odors escape when flushing the toilet in various wind conditions or with fans running. Occasionally though, when dumping with a wind blowing, some gasses may be pulled up from the sewer.
All in all, I think the vent is worth the investment.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
I just need to vent. airjeff Buyer Guidelines 15 05-02-2010 08:47 PM
louvered stainless steel vent or chrome vent toastie Roof Vents, Skylights & Fans 0 10-18-2009 04:01 PM
why is this vent here? Globie64 General Interior Topics 7 02-25-2008 06:30 PM
Loosening Vent Handles and Aluminum Vent Replacement kiincaidjess Roof Vents, Skylights & Fans 4 04-16-2007 10:37 PM
vent chuck schmit Furnaces, Heaters, Fireplaces & Air Conditioning 1 06-26-2006 06:42 AM
