Old 09-24-2011, 12:55 PM   #1
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Images: 8
Another Maxim Skylight Success
Kevin [Bambi_Bandit] did a great step-by-step post replacing OEM skylights with those made by Maxim in Texas. I was inspired. I just finished my replacement and, while I didn't do the outstanding job he did, I was successful. If you're interested the link is:
Skylight Replacement ę Cabin at Dogwood Lane
Linda Heuer. President Shen. Valley Unit
Greg Heuer, 2nd VP Shen. Valley Unit
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
Old 09-25-2011, 12:03 PM   #2
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
Nice, Greg. Think how the balloonists will enjoy the view of the top of your rig.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 09-25-2011, 12:46 PM   #3
2011 31' Classic
Images: 8
Thanks, Pat. Hope your recovery is going well. You will be in our thoughts as we head west.
Old 06-28-2012, 06:32 PM   #4
2016 30' Classic
Hilliard , Ohio
I've been pondering that for a couple years and finally installed one too. A quality product. Fit like a glove. Many thanks to those that shared experiences. Made the job easy. If you've been thinking about it, give it a try.
2016 Classic
2010 Ford F-150 Lariat
jeff4506 is offline   Reply With Quote
Old 06-28-2012, 07:00 PM   #5
Frank&Mike's Avatar
2016 27' Flying Cloud
Georgetown , Texas
Recently we had the Maxim skylight installed on our Airstream by Lance of Top's Texas Vintage Trailers. The quality is much better than the cheap piece of plastic that the Airstream factory installed. The Airstream factory had overtightened every screw so of course the skylight cracked every place that the skylight was screwed onto the Airstream ... and then they smeared a big messy slop of sealant over each of the cracked locations on the skylight. Talk about a perfect recipe for leaks.
The Maxim skylight (and installation by Lance) is a much higher quality. Photo attached.
I would recommend that anyone that has the factory installed skylight perform a close examination of their skylight installation and give very serious thought to replacing it.
Frank&Mike is offline   Reply With Quote
Old 07-14-2012, 02:19 PM   #6
2008 23' International CCD
Denver , Colorado
What great posts! Thank you. We have an Inland replacement skylight to replace ourselves. I like how the Maxim screws into the sides and not the top.
Question: is the Maxim a custom build? Or if I bought a 19x19 from Inland do I buy that from Maxim or do I need to give them measurements of that aluminum skylight frame?
Jim and Marsha
"Tow'd Hall"
AIR #35886
JimmyT is offline   Reply With Quote
Old 07-15-2012, 12:44 PM   #7
2011 31' Classic
Images: 8
Jimmy,
Call the folks at M. Tell them the AS you have and they will tell you what fits. There are lots of options for the three levels of lens, so talk it out with them. Yes, the M's are built to order.
Old 07-23-2012, 10:10 PM   #8
Denver , Colorado
Thanks, Greg. We'll do that tomorrow.
Jim and Marsha
"Tow'd Hall"
AIR #35886
Old 08-24-2012, 05:43 PM   #9
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
Just went through the process of ordering Maxim skylights for my 2012 Int'l. David Thornton was very speedy in providing me with what I needed for replacing the two "plastic" skylights that came standard. They are only slightly heavier than Saran Wrap. I guess you could say they don't add to the weight of the trailer, but that's about it. Looking forward to seeing how they look. Ordered them in powder coated white to match the roof, and with bronze-clear-clear as I had seen a trailer with this combo and thought it looked really nice.
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 08-24-2012, 06:16 PM   #10
dznf0g's Avatar
Oswego , Illinois
I really want to do this upgrade....but my "Saran Wrap" refuses to crack! I must have a crack to justify to DW!
May I ask the cost of a Maxim...ballpark?
Maybe a BFH would make a crack?
-Rich-
Old 08-24-2012, 09:25 PM   #11
Frank&Mike's Avatar
Georgetown , Texas
Our Maxim was $252.
Old 08-25-2012, 08:33 PM   #12
BAB
BAB's Avatar
2015 30' Classic
The two skylights for my 28' Int'l were $460.
_________________
ProPride 3P
AIR# 58452
Old 08-26-2012, 11:40 AM   #13
2011 31' Classic
Images: 8
Our pair cost $460 on 8/22/11.
Old 09-06-2012, 03:24 PM   #14
VeggieBullet's Avatar
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel , Florida
Hi Greg....Instersting upgrade, wondering how does it look from the inside?
Regards
Gus
Still One Nation under GOD
2 chronicles 7:14
VeggieBullet is offline   Reply With Quote
ARGOSY Door Lock Repair/Replace Phly36 Doors & Locks 23 04-07-2015 03:58 PM
Re-securing OEM Skylight Cracker Roof 14 07-11-2012 09:07 PM
International 23' CCD Signature skylight Deston General Repair Forum 0 09-19-2011 10:43 AM
Freezer cold, fridge NOT... I give up!! R2DTube Refrigerators 42 08-23-2011 07:24 PM
Aftermarket Skylight Install?? Rob&Julie Roof Vents, Skylights & Fans 6 03-22-2011 04:09 PM
