Old 11-09-2014, 02:17 PM   #1
grayling's Avatar
1961 16' Bambi
Avinger , Texas
Another Hehr lifter question for the Astradome
Just installed a new vent cover for my 61 Bambi. The old vent cover was a homemade welded metal and glass jobber held in place with bolts through the vent frame. I found the original lifters in a drawer and they appeared to still be operational so I cleaned, lubed, and reinstalled them.
Everything installed easy. However, when I spin the lifters to raise them, the rivet on the side of the lifter body hits the top part of the metal bracket at every turn.
The metal brackets each have identical bends at the top where the cylinder rides. Before I go bending 50+ year old metal around, is there some finesse I am missing?
Name:	ImageUploadedByAirstream Forums1415567027.277181.jpg
Name:	ImageUploadedByAirstream Forums1415567085.928264.jpg
Name:	ImageUploadedByAirstream Forums1415567142.648915.jpg
grayling is offline   Reply With Quote
Old 11-09-2014, 02:25 PM   #2
grayling's Avatar
1961 16' Bambi
Avinger , Texas
To be clear, the cylindrical outer body does turn as inner cylinder lifting occurs. Is this not supposed to happen?
Old 11-09-2014, 02:39 PM   #3
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
Bend the bracket so it doesn't hit the rivet. They are supposed to be flat, not bent.
Colin
Colin H is offline   Reply With Quote
Old 11-10-2014, 11:53 AM   #4
grayling's Avatar
1961 16' Bambi
Avinger , Texas
Bent them upward, works great! Thanks!
Old 11-10-2014, 11:55 AM   #5
Colin H's Avatar
1959 28' Ambassador
1949 24' Limited
Peru , New York
Anytime
Colin
Old 01-27-2015, 06:21 AM   #6
BambiTex's Avatar
1955 22' Safari
1967 26' Overlander
Clear Lake Shores , Texas
One of mine is seized. Have tried WD40 and torch. Any other suggestions?
BambiTex is offline   Reply With Quote
Old 01-27-2015, 06:36 AM   #7
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Not the torch. If the lifter is not already ruined use a carburetor or brake cleaner(spray can available at auto-parts store) and use it to dissolve the crud build up. Then operate the lifter and lube it with a white lithium type grease. Remember that WD 40 is not a lube.
Old 01-27-2015, 12:05 PM   #8
BambiTex's Avatar
1955 22' Safari
1967 26' Overlander
What is the floorplan of your 56 FC?
Old 01-27-2015, 12:06 PM   #9
BambiTex's Avatar
1955 22' Safari
1967 26' Overlander
It is really too bad nobody makes reproductions of those lifters. They could sell a bunch.
Astradome - did I order the wrong one? jessejane Windows, Doors, Locks & Vents 9 08-30-2013 05:07 PM
50's Hehr roof vent lifter arm rivet tool vintageair Roof Vents, Skylights & Fans 12 06-29-2011 01:37 PM
Astradome Installation Twinkie Roof Vents, Skylights & Fans 9 03-14-2008 07:10 AM
Astradome vent cover cookeville34 Roof Vents, Skylights & Fans 4 11-28-2006 05:42 PM
