06-09-2014, 02:30 PM
#41
1966 26' Overlander
Woodstock
, Georgia
I got the pin out with some serious pushing and a large screwdriver. The pins are shot, do I rivet it back on through the brackets?
06-09-2014, 03:30 PM
#42
1966 26' Overlander
Woodstock
, Georgia
got the dome lid off, its very brittle but amazingly does not leak. I am fixing it with sealant and fibertape. The Krylon fusion to paint it white.
10-04-2015, 07:08 AM
#43
1963 19' Globetrotter
Newton
, New Jersey
Originally Posted by ALANSD
what is done for the lifters that spin but do not raise the vent?
I think my issue is similar. The hinge that attaches between the lifting rod and vent cover popped off lifting rod. How does that attach to rod? Can it be re-attached? Is the rod supposed to spin where it attaches to hinge? Any help would be appreciated. Thanks!!
10-04-2015, 07:21 AM
#44
1962 22' Safari
2016 30' Classic
Southeast
, Michigan
The Hehr lifter rod was "peened" into the hinged bracket that attaches to the lid. It was a friction fit after the rod end was expanded on the bracket hole. There is not supposed to be any movement between the two parts. Twisting these apart on a "frozen" or stiff lifter is a common issue. I have seen two types of repair:
1) Welding
2) Drill and tap the rod end for screws and washers. Might have to use two small screws and/or lock tite to keep the rod end from being able to spin in the bracket.
If the lifter is stiff, crud and corrosion must be carefully cleaned out from inside the spiral track. Use of a pentrating oil may help. Do not try to force the lifter to move. If it is totally frozen, it may be corroded in place and may not be able to be saved. Penetrating oil may help free it. There are other methods that have been tried with some success, including partial disassembly, freezing, and carefull tapping in a with a hammer to break up the corrosive bonds.
Joe
WBCCI/VAC #702 & #6768
10-04-2015, 07:24 PM
#45
1958 22' Flying Cloud
Saint Helena
I have drilled out a couple of them, and then put in a self-tapping machine screw. Be certain to use a lock washer and, as I did, some blue thread lock liquid. Should be fine. Yes, they need to be cleaned periodically. Any residual oil makes for flypaper/dirt trouble that will gum up eventually. I clean them and lube w a dry silicone spray. Still, periodic cleaning is a good idea. Don't force them and they will serve you well.
-Michael
TAC CA-12
"All things in moderation, including moderation"
- Mark Twain
10-05-2015, 08:57 AM
#46
Corona
The old original vent cover operators, were designed to have some internal friction. The purpose of the friction was for the operator to stay in a selected open position while the coach is on the highways. The problem with them, as they aged, was the friction part, no longer existed.
When the internal friction of those operators was history, then simple vibration would further open the vent, which in turn, would blow off the trailer, when a on coming large vehicle would pass the trailer.
That was a very common occurence when I worked for Caravanner insurance company. I am sure that the same thing continues to happen today.
A redesigned vent operator is available, that replaces the original, does not depend on any friction, since it uses a threaded rod for opening and closing the vent. Therefore vibration has no effect on it.
Lubing the original operator makes it easier for it to further open, simply going down the road.
CAUTION: If the friction of the old operator is gone, then make sure the vent cover is completely closed when traveling. That will stop the cover from being blown off.
10-06-2015, 10:30 PM
#47
1962 22' Safari
2016 30' Classic
Southeast
, Michigan
Good point on the effects when the friction is gone Andy. I and others go further when travelling and use a bungee cord to keep the lifters from turning. Apply the cord from the front knob to the rear knob holding them in the full closed position.
Joe
10-11-2015, 06:55 PM
#48
Newton
, New Jersey
Thanks for tips. Doesn't seem to be a good original design IMHO. I went with the drilling/tapping solution. I used threaded rod with loctite and put a fender washer and lock nut on other side of hinge. So far, so good. I'm sure I'll have to be careful with them.
11-25-2016, 12:37 PM
#49
1954 22' Safari
Deerfield
Just an update - and thanks - for everyone's thoughts on how these Hehr / LeDeux lifters work... and more importantly, your ideas for how to repair them.
After one of ours came loose from its hinge (which is riveted to a VTS reproduction Astrodome) I found a local metal fabrication shop with a bench press and wide variety of taps.
I supplied them with small machine screws (maybe 1/4" diameter and 1.5" long, something like that) and washers; they were able to tap the solid bar in the end of the lifters, thus securing the lifters to the lid. FAR more peace of mind than the way they were "peened" in to begin with.
12-01-2016, 08:36 AM
#50
1966 26' Overlander
Woodstock
, Georgia
05-14-2019, 01:07 PM
#51
1965 20' Globetrotter
Bromsgrove
, Worcestershire
This is the thread that keeps on giving, many thanks to all the contributors.
I’m fixing up a ‘65 Globetrotter has has the Ladeau adjusters in place but I don’t have a cover.
What I need to know is:- are the hinges that are fitted to the top of the adjusters open or closed when the vent cover is in the fully down position?
02-15-2022, 10:53 AM
#52
1959 18' Globetrotter
le muy
, French Riviera
Very helpfull post ! I have to repair the ledeux openers off my 59 globetrotter ! thanks !
09-03-2022, 12:44 PM
#53
1965 24' Tradewind
Lemon Grove
ladeux times two
wish i had seen this before i took mine apart. cleaned and oiled with wd40. super smooth operation, so much so that even closed blew off on the highway taking all the gear. Oh well, lesson learned.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Repairing roof vent covers?
JohnGalt48 |
Roof Vents, Skylights & Fans |
21 |
04-15-2007 04:45 PM |
Roof Vent Covers
Dwight |
2 |
10-13-2003 10:16 AM |
Roof Air Problams
ViewRVs |
Mechanics Corner - Engines, Transmission & More... |
22 |
01-28-2003 06:40 PM |
Roof Vent Original?
pepper48 |
6 |
11-09-2002 05:44 AM |
Roof AC units Questions
FrankR |
Furnaces, Heaters, Fireplaces & Air Conditioning |
15 |
07-22-2002 01:35 PM |
