Old 10-04-2015, 08:08 AM   #43
1963 19' Globetrotter
Newton , New Jersey
Originally Posted by ALANSD View Post
what is done for the lifters that spin but do not raise the vent?
I think my issue is similar. The hinge that attaches between the lifting rod and vent cover popped off lifting rod. How does that attach to rod? Can it be re-attached? Is the rod supposed to spin where it attaches to hinge? Any help would be appreciated. Thanks!!
rfandy is offline   Reply With Quote
Old 10-04-2015, 08:21 AM   #44
66Overlander's Avatar
1962 22' Safari
2016 30' Classic
Somewhere , in the USA
Images: 41
The Hehr lifter rod was "peened" into the hinged bracket that attaches to the lid. It was a friction fit after the rod end was expanded on the bracket hole. There is not supposed to be any movement between the two parts. Twisting these apart on a "frozen" or stiff lifter is a common issue. I have seen two types of repair:
1) Welding
2) Drill and tap the rod end for screws and washers. Might have to use two small screws and/or lock tite to keep the rod end from being able to spin in the bracket.
If the lifter is stiff, crud and corrosion must be carefully cleaned out from inside the spiral track. Use of a pentrating oil may help. Do not try to force the lifter to move. If it is totally frozen, it may be corroded in place and may not be able to be saved. Penetrating oil may help free it. There are other methods that have been tried with some success, including partial disassembly, freezing, and carefull tapping in a with a hammer to break up the corrosive bonds.
Joe
WBCCI/VAC #6768
66Overlander is offline   Reply With Quote
Old 10-04-2015, 08:24 PM   #45
bevman's Avatar
1958 22' Flying Cloud
Saint Helena , California
I have drilled out a couple of them, and then put in a self-tapping machine screw. Be certain to use a lock washer and, as I did, some blue thread lock liquid. Should be fine. Yes, they need to be cleaned periodically. Any residual oil makes for flypaper/dirt trouble that will gum up eventually. I clean them and lube w a dry silicone spray. Still, periodic cleaning is a good idea. Don't force them and they will serve you well.
-Michael
TAC CA-12
"All things in moderation, including moderation"
- Mark Twain
bevman is offline   Reply With Quote
Old 10-05-2015, 09:57 AM   #46
The old original vent cover operators, were designed to have some internal friction. The purpose of the friction was for the operator to stay in a selected open position while the coach is on the highways. The problem with them, as they aged, was the friction part, no longer existed.
When the internal friction of those operators was history, then simple vibration would further open the vent, which in turn, would blow off the trailer, when a on coming large vehicle would pass the trailer.
That was a very common occurence when I worked for Caravanner insurance company. I am sure that the same thing continues to happen today.
A redesigned vent operator is available, that replaces the original, does not depend on any friction, since it uses a threaded rod for opening and closing the vent. Therefore vibration has no effect on it.
Lubing the original operator makes it easier for it to further open, simply going down the road.
CAUTION: If the friction of the old operator is gone, then make sure the vent cover is completely closed when traveling. That will stop the cover from being blown off.
Old 10-06-2015, 11:30 PM   #47
1962 22' Safari
2016 30' Classic
Images: 41
Good point on the effects when the friction is gone Andy. I and others go further when travelling and use a bungee cord to keep the lifters from turning. Apply the cord from the front knob to the rear knob holding them in the full closed position.
Joe
WBCCI/VAC #6768
Old 10-11-2015, 07:55 PM   #48
Newton , New Jersey
Thanks for tips. Doesn't seem to be a good original design IMHO. I went with the drilling/tapping solution. I used threaded rod with loctite and put a fender washer and lock nut on other side of hinge. So far, so good. I'm sure I'll have to be careful with them.
Old 11-25-2016, 01:37 PM   #49
bredlo's Avatar
1954 22' Safari
Deerfield , Illinois
Send a message via AIM to bredlo
Just an update - and thanks - for everyone's thoughts on how these Hehr / LeDeux lifters work... and more importantly, your ideas for how to repair them.
After one of ours came loose from its hinge (which is riveted to a VTS reproduction Astrodome) I found a local metal fabrication shop with a bench press and wide variety of taps.
I supplied them with small machine screws (maybe 1/4" diameter and 1.5" long, something like that) and washers; they were able to tap the solid bar in the end of the lifters, thus securing the lifters to the lid. FAR more peace of mind than the way they were "peened" in to begin with.
bredlo is offline   Reply With Quote
Old 12-01-2016, 09:36 AM   #50
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Hehr repair manual
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Repairing roof vent covers? JohnGalt48 Roof Vents, Skylights & Fans 21 04-15-2007 05:45 PM
Roof Vent Covers Dwight Roof Vents, Skylights & Fans 2 10-13-2003 11:16 AM
Roof Air Problams ViewRVs Mechanics Corner - Engines, Transmission & More... 22 01-28-2003 07:40 PM
Roof Vent Original? pepper48 Roof Vents, Skylights & Fans 6 11-09-2002 06:44 AM
Roof AC units Questions FrankR Furnaces, Heaters, Fireplaces & Air Conditioning 15 07-22-2002 02:35 PM
