Old 10-31-2013, 05:30 AM   #29
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Thanks for the information on removing the T crank handles from the vent cover lifts. I pulled down and they did separate. I see they are held in position with what we used to call a "Jurgens" ball plunger. Just a simple spring and ball bearing that is crimped into the square shaft. This design makes for a simple and reliable attachment mechanism.
I was surprised the T handles weren't held in position with a set screw similar to the light fixture rotary switch knobs, or the window crank handles.
I see I have one stuck inner shaft to repair. The outer barrel rotates upward on the helix, the the inner shaft doesn't extend. Now I know how to repair this actuator.
Ah, the fun of learning how old Airstreams were made. And the method of repairing a corroded lifting actuator described in this thread is very valuable information.
Thanks again for your help,
David
Old 10-31-2013, 06:10 AM   #30
1973 Argosy 24
Frostproof , Florida
The vent parts on eBay seem to be the same as on my 1972 Argosy 24. I'm on it, and thanks for the link.
Carolinda
1973 Argosy 24
TV - 2011 Tundra
Now at the getting much prettier stage!
Carolinda is offline   Reply With Quote
Old 11-10-2013, 09:27 AM   #31
RankAm's Avatar
1956 22' Flying Cloud
Dallas , Texas
I am disassembling and cleaning the Hehr roof vent on my 56 Flying Cloud. I have the two Ladeau lifters that I would like to remove and clean. I would like to remove the whole assembly from the frame for the vent cover, but I cannot figure how best to do that.
Can anyone tell me how the lifters are attached to the frame of the vent cover? Is the assembly riveted, bolted, peened, other? I cannot feel much with my finger tip.
Any suggestions as to how I should tackle this?
Thanks, Hank
RankAm is offline   Reply With Quote
Old 11-10-2013, 02:02 PM   #32
Attachment 199685
Thanks, Hank
Take the gasket off.
Then you will clearly see how the operators are attached.
Old 11-11-2013, 11:24 AM   #33
RankAm's Avatar
Dallas , Texas
Thanks, Andy. I cannot get back to this right now, but I will remove the gasket as you recommend. That will show how the bracket attaches to the frame, rather than showing how the operator shaft is attached to the bracket? Hank
Old 03-18-2014, 10:59 PM   #34
SilverMiette's Avatar
1972 31' Sovereign
1964 30' Sovereign
Richland , Washington
I have a set of lifters if anyone wants them. Just PM me. They work good, extend all the way up and down. They are off a 64 Sovereign which I drove for 5 hours without any vents blowing off so this set has good friction. The hinges are not frozen, but rusty.
Kelly
1972 31' Sovereign
1964 30' Sovereign
2009 GMC Sierra 2500HD
http://www.silversojourner.com/
SilverMiette is offline   Reply With Quote
Old 03-20-2014, 09:29 AM   #35
1972 31' Sovereign
1964 30' Sovereign
Someone claimed the lifters. Thanks.
Sent from my Nexus 4 using Airstream Forums mobile app
Kelly
1972 31' Sovereign
1964 30' Sovereign
Old 04-13-2014, 12:58 PM   #36
1980 31' International
1962 19' Globetrotter
Naples , N. Idaho
Ladeau round knob
would you be willing to sell one round lifter knob. We are missing one on our 1950 Liner we are working on.
yarlj is offline   Reply With Quote
Old 04-13-2014, 01:12 PM   #37
1972 31' Sovereign
1964 30' Sovereign
Sorry, I don't have anymore lifters or knobs. Just had the one set.
Kelly
1972 31' Sovereign
1964 30' Sovereign
Old 06-09-2014, 12:14 PM   #38
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I am trying to remove the astro solar dome lid to repair it, but not sure where to pry the metal apart to release it...I don't want to breaak the lifters...
Is it inside by the lifter, or outside where the pin gores thru?
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 06-09-2014, 12:23 PM   #39
Hittenstiehl's Avatar
1961 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
Alan if the same as ours the two little tabs on either side pry gently apart and will free the lifter from the bracket.
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 06-09-2014, 01:52 PM   #40
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
you push out the pin that looks like a rivet?
AIR #005
retired!
Old 06-09-2014, 02:30 PM   #41
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I got the pin out with some serious pushing and a large screwdriver. The pins are shot, do I rivet it back on through the brackets?
AIR #005
retired!
Old 06-09-2014, 03:30 PM   #42
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
got the dome lid off, its very brittle but amazingly does not leak. I am fixing it with sealant and fibertape. The Krylon fusion to paint it white.
AIR #005
retired!
Repairing roof vent covers? JohnGalt48 Roof Vents, Skylights & Fans 21 04-15-2007 04:45 PM
Roof Vent Covers Dwight Roof Vents, Skylights & Fans 2 10-13-2003 10:16 AM
Roof Air Problams ViewRVs Mechanics Corner - Engines, Transmission & More... 22 01-28-2003 06:40 PM
Roof Vent Original? pepper48 Roof Vents, Skylights & Fans 6 11-09-2002 05:44 AM
Roof AC units Questions FrankR Furnaces, Heaters, Fireplaces & Air Conditioning 15 07-22-2002 01:35 PM
