Old 04-29-2009, 11:17 AM   #1
Santa Fe , New Mexico
Airstream Wrong! Who knows skylight covers?
I have a 2006 Safari 25' SE, Front Bedroom model.
Problem: White skylight cover over front bedroom blew off. Airstream's tech people were given above model number and VIN. They told me I needed a Vent-Line cover, model BV-0554-01. I ordered this cover from Tweety's,an on-line RV parts outfit. When I went to install it, I noted that that part is clearly not the proper replacement cover. The cross bar on the part Airstream said I needed was different from the cross bar that didn't blow off (only the plastic cover blew, not the associated cross bar). The BV-0554-01 seemed large and there didn't seem to be any way that the curled metal hinge on the BV-0554-01 could affix to the curled metal hinge of the frame attached to the roof.
Does anyone know the EXACT part number and manufacturer that will work on this trailer. I'm disappointed that Airsteam couldn't provide correct information.
mistermcfrug is offline   Reply With Quote
Old 04-29-2009, 11:24 AM   #2
Lily&Me's Avatar
Normal , Illinois
Can't help you with your specific information, but will commiserate and tell you that our window which blew out had a wrong part number in Airstream's system---had to take pictures of it and send to get the right one.
Old 04-29-2009, 11:57 AM   #3
CanoeStream's Avatar
St. Cloud , Minnesota
The crank-open vents used the last few years are notorious for sunlight destruction of the plastic. I sure wouldn't replace it with the same cheap parts. The wires for a power vent are preinstalled right alongside your front vent.
See:
http://www.airforums.com/forums/f455...a-s-37843.html
http://www.airforums.com/forums/f455...ion-45028.html
You could poke around any RV dealer for possible crank-open vents to replace. I store inside so mine will take a bit longer to deteriorate. When it does I'll think about another Fantastic Fan. MaxxAir might be considered as it actually can give ventilation while going down the road. I'm not sure if either of those are as economical as you wished at http://www.airforums.com/forums/f455...ari-48869.html.
5 meter Langford Nahanni
Old 04-29-2009, 01:24 PM   #4
Frustrated--Still need an answer
Thanks for the above comments but I gotta tell ya, I'm sitting here with a hole in the top of my Airstream and no one seems to know what part is needed to fix it. Yeah, I'm happy to consider another fantastic fan, but right now, I need a skylight cover because I'm sick of re-working the duct tape and plastic up there. Other owners have talked about crappy Airstream skylight covers but absolutely NO ONE seems to know what they bought or some dealer provided to replace their covers.
I'm more than a little disappointed with this Airstream purchase. I sure would appreciate a thoughtful comment.
Old 04-29-2009, 01:32 PM   #5
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
We have a 2005 25FB. It originally came with the crank open roof vent that you had. Ours did the same thing within the first year. We decided to replace it with a second Fantastic Fan. It cost a few bucks, but we have not regretted. When both fans are going (one pulling in and the other pushing out), it creates a wind tunnel in side the trailer.
The original manual vent was a piece of junk.
Brian
SuEllyn & Brian McCabe
moosetags is online now   Reply With Quote
Old 04-29-2009, 05:39 PM   #6
2dabeach's Avatar
2007 25' Safari FB SE
North/East , New Jersey
We had the same problem with our 2007 25' FB and installed a MaxxAir II vent cover over the original equipment bedroom vent to keep the sun off the vent. I also have a spare cover in case it goes again (picture attached). I picked up the cover from my Airstream dealer. The replacement vent cover is made for Elixir Industries, Elkhart, IN 46516 and the package noted with a green label indicating it was model # 7291 for Jensen Metal Base Vents. The following numbers were on the white label on the package 17-J7291RWH-C Lid, White, Jensen With. The bar code number is 050391740252. Good luck..
2007 Safari 25' FBSE LS
2006 GMC Sierra 2500HD Crew Cab 4WD Duramax
2dabeach is offline   Reply With Quote
Old 04-29-2009, 05:50 PM   #7
2005 19' International CCD
Roswell , Georgia
part details
This is what we used on our 2005 19ft Bambi CCD.
replacement part
mfg in china for elixir industries
elkhart, IN
17-J7291RWH-C Lid
White, Jensen, without hinge, pin style
upc code: 50391-74025
airstream item 381606-102
Hope it helps.
joelbert is offline   Reply With Quote
Old 04-29-2009, 08:55 PM   #8
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Not a skylight!
Hi, I replaced the same vent cover mentioned and pictured in the two previous posts. I bought mine at Camping World; Maybe cheaper than Airstream dealer price. Also the wheel broke off of the lift arm, so I replaced that too. The original arm had a plastic roller and the replacement has a metal roller.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 04-30-2009, 12:20 AM   #9
Suburbia , Sunny So Cal
Brian
Exactly the same scenario for us except our trailers an '06 and my name is not Brian.
I'd rather be boon docking in the desert.
WBCCI 6731 FCU
AIR# 13896
CA 4
Goin camping is offline   Reply With Quote
Old 04-30-2009, 02:16 PM   #10
Wayward's Avatar
Cary , North Carolina
same problem
Odd thing here is we just hooked up our '06 front bedroom model this Sunday to head out for the mountains and the plastic front vent cover was lying on the ground next to the Airstream. Junk plastic. Did they put a self destruct 2 year timer in that plastic?
I had to leave Sunday, so I looked around the local WalMart and found a clear 13"x13" plastic dish drainpan in the kitchenware section. I flipped it upside down, drilled a couple of pop rivets into the metal crank arm and was good to go. Working fine for an emergency fix.
I think I will add another Fantastic Fan - especially if the power is already there. Will I see the wires in the roof space when I pull the old vent out?
...........Scott
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Old 04-30-2009, 06:42 PM   #11
Dishpan? Salad bowl? They all work! (and don't tell me the wayback machine doesn't exist. That was post 29704 at AIR. ).
Old 05-01-2009, 11:07 AM   #12
Wayward's Avatar
pretty funny! - no wonder WalMart encourages RV parking - they can sell more RV spare parts from the Kitchenware Dept. that way
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Old 05-17-2009, 06:56 PM   #13
tpi
Trabuco Canyon , California
My '05 uses a "new style Jensen" vent cover. It rotted out about a year from new. I spray painted the tops of the new covers with Krylon plastic paint, white. The new ones appear to still be in good shape after 3 years.
tpi is offline   Reply With Quote
Old 05-17-2009, 08:26 PM   #14
Skylights, Solardomes, Astrodomes, all have dual purpose, at least those that open.
A couple of after market replacements, also have a "thermal barrier."
They let in air, and daylight. Some are white, some are solar gray.
Painting them, defeats the light transmission.
Are these REAL AIRSTREAM wheel covers? flynmike Wheels, Hubs & Bearings 7 12-25-2008 09:31 AM
Skylight Dilemma moosetags General Interior Topics 6 04-25-2008 11:39 AM
1998 31' Airstream Limited skylight John Hughes Member Introductions 3 12-13-2005 04:53 AM
Skylight Insight nevisstudio Roof Vents, Skylights & Fans 2 08-28-2004 09:32 AM
