Old 04-23-2009, 08:51 PM   #1
Grand Master's Avatar
1963 24' Tradewind
Anderson / Sun City , Indiana / Arizona
Advantages / Disadvantages of Astrodomes
My Astrodome on my 1963 tradewind is long gone. I have replaced it with an aluminum cover.
I am now wondering if I would enjoy the skylight effect of an Astrodome.
What are the pros and cons?
Is there enough light during sunlight hours to make it worthwhile?
Is it too bright on some occasions?
Mike Brumback
Grand Master is offline   Reply With Quote
Old 04-23-2009, 10:06 PM   #2
Mike Brumback
Astrodomes or solardomes that are white, that have a thermal barrier, let some light in, although a little harsch.
The solar gray covers, that have a thermal barrier, let in more light, that is soft, but no direct sun light.
Fiberglass covers let in brown light, if any light at all, and are single thickness.
Gel coated fiberglass covers, are single thickness and let in zero light.
The white or solar gray covers never allow "bright" sun light in.
Metal covers allow no light, ever. But they do let in heat and/or cold as the case may be.
Old 04-24-2009, 06:34 AM   #3
safari62's Avatar
1962 22' Safari
1957 22' Custom
1963 16' Bambi
Vacationland , Maine
Images: 43
or convert to a Wally hatch
by adding a hinged frame with latches you can have sunlight and more ventilation. Lots more work but is great when you need it.
Name:	astrodome 001 - Copy (3).jpg
ID:	79146   Click image for larger version
safari62 is offline   Reply With Quote
Old 04-24-2009, 06:53 AM   #4
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
For less than $10 you can put a corrugated Polycarbonate window in your aluminum cover and get all the advantages of a insulated window with diffused light at little cost and one hour's work. The sheeting, with hollow tubular air pockets, is available at many home stores. I think you can find pictures somewhere here in another thread.
Advantages and disadvantages of 28 vs. 34 Scott Hopkin Airstream Trailer Forums 11 02-25-2005 10:32 AM
Disadvantages of polishing... InsideOut Cleaning, Stripping & Polishing 13 09-03-2003 06:29 AM
