Old 06-17-2011, 02:20 PM   #1
aircampr's Avatar
2015 23' International
Lake Forest Park , Washington
Images: 21
A Quieter Galley Fan?
Has anyone replaced their galley fan with a much quieter unit?
We are just starting to enjoy our 2007 19' Safari SE Bambi. It is a class act in almost every way, except the Galley Fan is uncomfortably loud. We are looking to replace it with something much quieter.
Charlie
aircampr is offline   Reply With Quote
Old 06-17-2011, 02:34 PM   #2
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
I've never thought the vent hood fans to be terribly effective but the one on my previous trailer was particularly loud. I put a 10 ohm (best as I can recall) resistor in series with the motor. That tamed the beast, but as the motor ran slower, it was even less effective. It still pushed the flapper door wide open so it was moving air... If making a pot of spaghetti, I've found the Fantastic Fan in the ceiling accompanied by an open window to be the most effective solution.
AIR 47751
Silver Goose is offline   Reply With Quote
Old 06-17-2011, 03:08 PM   #3
Charlie
Older Airstreams used a switch for the ceiling vent fan motors.
It was a 2 way switch, with a center off.
Flipping the switch to one side, applied the full battery voltage to the motor. Flipping the switch to the other side, applied the battery voltage though a 10 watt, one ohm resistor.
That made the fan run slower and quieter, but if you wanted it at full speed, all you had to do was flip the switch.
Agani, the center position of the switch, was the "OFF" position.
A switch could easily be installed on later models, just make sure that the resistor does not touch anything, as it does get pretty warm.
Old 06-17-2011, 03:35 PM   #4
2008 27' Classic FB
Burkburnett , Texas
The OP indicated he had an '07. My '08 came equipped with the center off, 2 speed motor switch, so his might also but he didn't say. You jogged my memory, that may have been a 1 ohm, 10 watt resistor I added. It was also a 2-speed model so I had low and very low, but it was quiet!
AIR 47751
Old 06-17-2011, 04:09 PM   #5
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Santa Fe , New Mexico
Go to Radio Shack and by a 12V rheostat and knob. Take off the cover plate over the fan/light switches and drill a hole to mount rheostat. Connect wires and you have a variable speed fan.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Old 06-17-2011, 04:33 PM   #6
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
from the Restoration Rally
I was shown a kitchen fan that was replaced with an off the shelf computer cooling fan. Fit right in and was it quiet and powerful.
Old 06-17-2011, 06:16 PM   #7
aircampr's Avatar
Images: 21
OK. SOme good ideas here. We have a one speed fan in our '07, but it would be great to have two speeds. i will play with a new switch and resistor for low speed option. If that is not satisfactory, then begins the search for a fan replacement.
Also I would like to rig an inside means to lock and unlock the fan flapper door. At this stage I am always forgetting to attend to that, and discover at inconvenient times. (Boiling water for coffee in the morning, before being dressed for the nieghbors... and realizing the vent is still latched on the outside!)
Thanks for the good suggestions. I will post further findings later.
Cheers,
Charlie
Old 06-17-2011, 06:27 PM   #8
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Charlie
Felt the same way at first....then realized that the most use came in the morning while making breakfast, coffee brewing..... too tired to notice, bacon crackling... too loud to hear it, meal ready....too frustrated trying to wake DW!
What Fan..
But after awhile it became obvious that it didn't do much even on high, so we just up the speed on the FV fans and live with it.
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel itís supposed to be done"Ö..
Amanamus
"Tahawus"
Old 06-17-2011, 06:45 PM   #9
2008 27' Classic FB
Burkburnett , Texas
Charlie
Or it's unlatched and the wind picks up in the middle of the night, and you're awaken to a flap-tap-ratta-tap-flap! The more I think about this, the more I appreciate the Fantastic Fan.
AIR 47751
Old 06-17-2011, 07:32 PM   #10
These don't flap...MUCH
There is no latch, so nothing to remember.
???Some AS no 2 speed switch???
Name:	STAINLESS UP-GRADES 006.jpg
W. H. Auden
Amanamus
"Tahawus"
Old 06-17-2011, 07:36 PM   #11
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I put a 10 ohm 10 watt resistor on the switch and it makes the fan much quieter but still has enough umph to open the flap. Anything more that 10 ohms and the flap won't open. $2.
2019 Ford Expedition Platinum
Old 06-19-2011, 02:23 PM   #12
aircampr's Avatar
Images: 21
OK, I have experimented with using power resistors in series with the switch on the stock fan in our '07 19 ft Safari/Bambi SE. With each of several resistance values:
- I measured the noise level with a sound level meter at three locations;
- I noted the opening of the flapper door (which is pictured in Robert Cross's post above).
- I made a qualitative assessment of the ventilation with a teapot boiling on the left rear burner (on max heat).
Sound levels, in dB A-weighted, were recorded at: 1) the galley, 2) the dinette, 3) the aft bed near pillows. The dB levels may not be absolutely correct, but relative differences are meaningful:
Location= Galley Dinette Bed Flap%Open Ventilation
Fan Off 39dB 39dB 39dB 0% none
14 Ohms 70dB 55dB 48dB 50% inadequate
8 Ohms 74dB 58dB 50dB 66% doubtful
5.5 Ohms 76dB 62dB 52dB 75% maybe OK
No Ohms 88dB 70dB 58dB 100% OK
(stock)
FantstcFan 47dB 48dB 43dB -- --
My conclusions:
1) The stock Phillips fan is a very noisey design and should be upgraded (maybe has been?) in future airstreams. It generates very much more noise than a fantastic fan at lower flow rates (than the FF).
2) One could easily and inexpensively install a switch under the hood to provide two speeds, where the low speed uses about a 5 Ohm resistor. This noticeably reduces sound levels with perhaps acceptable reduction in ventilation flow (in limited circumstances - like bring water to boil for coffee). Any resistance greater than this in my opinion would necessitate additional ventilation from ceiling vents or open window(s).
3) I have ordered a couple of 4-3/4" dia computer fans, since I desire MUCH lower noise levels than can be achieved with a series resistor on existing fan.
I will report how this works out in a week or so.
Cheers,
Charlie
Old 06-19-2011, 04:01 PM   #13
2008 27' Classic FB
Burkburnett , Texas
I can tell you're serious about this... I just took my dB meter out there and checked mine.
With the meter on the burner cover
Fan off 50dB
Fan low 68dB Flap 50% open
Fan high 76dB Flap 100%
The vent hood in mine is a Ventline made by Dexter. It has the 2 speed blower. I use the light as a night light more than I use the vent hood. As stated earlier, the FV on the ceiling seems much more efficient. Maybe we can encourage Fantastic to get into the vent hood business!
AIR 47751
Old 06-19-2011, 04:37 PM   #14
aircampr's Avatar
Images: 21
Thanks YankeeDoodle. I suspect they must be using a nicer (quieter) fan in the Classic.
Parallax Power Supply Fan Noise Bluto Batteries, Univolts, Converters & Inverters 9 09-30-2012 09:21 AM
Fan Motor Okiegent Roof Vents, Skylights & Fans 19 05-15-2011 11:58 AM
Need help, Kool O Matic exhaust fan destroyed frankfarmer Roof Vents, Skylights & Fans 2 05-06-2011 05:34 AM
Bedroom ceiling fan switch? seacure 1987 - 1989 Excella 1 04-30-2011 04:45 PM
