Old 03-10-2012, 09:04 AM   #21
aircampr's Avatar
2015 23' International
Lake Forest Park , Washington
Images: 21
OK, it has taken me several months to get back to this, but we finally have a galley fan which no longer roars.
I found a suitable replacement fan, made by Orion, which i ordered from Mouser Electronics for about $80. It moves more air than the stock fan, for the same wattage, and is considerably quieter. I drilled out the rivets to remove the original fan, mounting bracket and all. Then, using new mounting holes, and a homemade hardwood bracket, I mounted the new fan in its place. Rubber washers provide vibration isolation. Aluminum "speed tape" seals a small gap around the periphery of the fan (to the plenum chamber). Then I added a toggle switch to side of the box to switch in a 3 Ohm resistor, so the fan has two speeds.
On low speed this fan is very quiet, yet exhausts the fumes from a single burner boiling water in a tea kettle. On high speed, it exhausts better than the stock fan, but is still quieter. (will post measurements later).
1 Original fan in plenum box, removed from hood:
2 New Orion fan:
3 New fan mounted in plenum:
4 View from below, before plenum re-installed under hood (filter removed):
This project was mostly "thinking." The engineering took way longer than the actual replacement, which was about an hours effort plus a couple trips to the hardware store.
Next: how to lock/unlock the vent flap from inside the trailer...
Charlie
aircampr is offline   Reply With Quote
Old 03-10-2012, 09:34 AM   #22
"Cloudsplitter"
Thumbs up Flapper...
Charlie,
Look forward to the pic's....
POI... found ours to be a lot quieter if stainless vent held completely open.
Maybe I won't be changing the fan out after all..it's up to SWMBO.
Old 03-10-2012, 10:22 AM   #23
SmokelessJoe's Avatar
1976 Argosy 24
now being enjoyed by Heath and Mary in , Vermont
Charlie,
Thanks for the good picture story.
I recently paid Outdoors Mart $80 for a regular issue NOISEY fan.
This spring I will check to see if my 1976 Argosy can accept this modification.
Sergei
From my iPad
SmokelessJoe is offline   Reply With Quote
Old 03-11-2012, 07:03 PM   #24
aircampr's Avatar
Images: 21
Reposted with photos
2 New Orion fan:
Charlie
ID:	153107   Click image for larger version
ID:	153109   Click image for larger version
Parallax Power Supply Fan Noise Bluto Batteries, Univolts, Converters & Inverters 9 09-30-2012 09:21 AM
Fan Motor Okiegent Roof Vents, Skylights & Fans 19 05-15-2011 11:58 AM
Need help, Kool O Matic exhaust fan destroyed frankfarmer Roof Vents, Skylights & Fans 2 05-06-2011 05:34 AM
Bedroom ceiling fan switch? seacure 1987 - 1989 Excella 1 04-30-2011 04:45 PM
