Old 11-22-2006, 03:55 PM   #1
1977 31' Excella 500
plano , Texas
Question 77 excella 500 bathroom vent problem
I have a problem with the exhaust fan in my bathroom. After 30 years, the propeller needs to be replaced. I was told that is not available by my local Airstream dealer and my inlandrv. I was told that it is a max-air, but I don't know for certain. All it says on it is "Made in Sweeden Mod GY11 Prod No 242079" and a serial number. What options do I have to fix/replace it?
-thomas
tschat is offline   Reply With Quote
Old 11-22-2006, 05:30 PM   #2
JimGolden's Avatar
You might try taking a picture and posting it on here. If Inland Andy can't get it, then you probably can't find it.
You could either replace the whole thing, or try to adapt a different blade if the rest of the fan works OK.
Go to the hobby shop and get yourself a 6" diameter model airplane propeller
Mine still works, but it sure isn't pretty to look at anymore
- Jim
JimGolden is offline   Reply With Quote
Old 11-22-2006, 06:26 PM   #3
Excella CM's Avatar
1978 31' Excella 500
Venice , California
What does the impellor look like? What are the dimetions? How big is the motor shaft hole and what shape?
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Poor design on slide bathroom door lbrodsky 2000 - 2004 Safari 17 09-14-2022 01:01 PM
Engine Revving Problem winner Mechanics Corner - Engines, Transmission & More... 19 02-08-2010 10:05 PM
Larger Fan Blades in top Vent Sav'h Steve Roof Vents, Skylights & Fans 5 07-09-2003 05:35 PM
1981 Airstream Excella Univolt dienst1 Airstream Motorhome Forums 1 08-20-2002 09:05 AM
Hitch problem wyhjr Hitches, Couplers & Balls 8 07-22-2002 05:29 PM
