Old 06-03-2016, 09:37 AM   #1
So it Begins
1965 24' Tradewind
Lake Worth , Florida
'65 Vent Crank Replacement Parts
Newbie here with a '65 Tradewind.
When we brought her home, the vent covers were missing, so we ordered new Solardome covers as our first order of business to get her all closed up from the elements. In the meantime, hubby has been trying to unstick the Hehr vent lifters to no avail. He removed them from the vent frames and they have been sprayed, soaked (for 2 weeks), heated and he still can't get them to budge. These are the manual cranks, two per vent so it could be lifted straight up, if that helps describe them.
We've read all the advice on here on how to unstick them but now we just have 3 stuck and one broken. Oops
I'm now regretting buying the covers because maybe we should have just bought entire new vents for the prices I'm seeing. A couple weeks back I found replacement lifters online for something crazy like $85 each. We need four.
Looking for some direction on where to purchase replacement lifters for less than $85 a pop or whether we should suck it up and get new vent units and chalk up our premature purchasing of the covers to a rookie mistake. What would you all do? We hate to replace anything that can be saved but not sure in this case.
Thanks in advance!
vintagepatch is offline   Reply With Quote
Old 06-03-2016, 09:56 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Not sure we are in the same boat but here goes. My trailer had crank lift mechanism, one per vent. The cranks would turn but the vent would not lift. Turns out the soft metal gear in the mechanism was stripped. I opened the gear case and found they only used 120 degrees of the gear so I just rotated the gear 120 degrees and was back in business.
I had sent a picture of the crank mechanism to Jackson and their position was they never used them even though every Airstream I ever saw with the vertical lift vent had them.
2004 Excursion 4x4
Old 06-03-2016, 04:33 PM   #3
Cochese's Avatar
1965 26' Overlander
Tulsa , Oklahoma
I have 2 that I will sell!
Cochese is offline   Reply With Quote
Old 06-03-2016, 05:20 PM   #4
So it Begins
1965 24' Tradewind
yahoo!
Sounds great! They open and close, right? LOL.
Send me a private message with price, including shipping to 33460 and provide your paypal email address, or mailing address if you prefer a check. Cool!
Edited to include: And send a pic too, just to be sure we are on the same page.
Old 06-03-2016, 05:24 PM   #5
So it Begins
1965 24' Tradewind
Thanks for the advice, but we are talking about two different types of lifters here. From what I can tell, the Hehr lifters we have were only used until 1965 and are two per vent so that the whole lid lifts straight up.
I appreciate you trying to help. Happy Trails!
Old 06-13-2016, 12:59 PM   #6
1966 24' Tradewind
Seattle , Washington
I have a 66 Tradewind with seized vent lifters as well. I'm going to try soaking the lifters in white vinegar. It's my understanding that the acidic nature of the vinegar will break the corrosion bond between aluminum surfaces.
I'll post my results soon..
Spidermans is offline   Reply With Quote
Old 06-13-2016, 03:18 PM   #7
Cochese's Avatar
1965 26' Overlander
Tulsa , Oklahoma
Name:	ImageUploadedByAirstream Forums1465852710.862475.jpg
Old 06-29-2016, 09:41 AM   #8
1964 22' Safari
Bend , Oregon
Do you still have the Hehr actuators?
Harley Kathy is offline   Reply With Quote
Old 08-27-2016, 03:36 PM   #9
PSP
1962 19' Globetrotter
Albany , California
Anybody know where to get one of those triangle hinges that the actuators insert into. I broke one.
PSP is offline   Reply With Quote
Old 08-29-2016, 03:20 AM   #10
If you can purchase the vent lifters used, you're in good shape. But the new/replacement part is a larger diameter than the original, and, thus, does not fit into the (upper) bracket in the old vent housing like it should. I only needed one lifter for my '65 Caravel. Bit the bullet, bought the replacement, and had it installed in Jackson Center. It will only work partially, as the second stage of the rotating lift mechanism bumps the housing on its way up and out of the "case."
srrobertsiii is offline   Reply With Quote
Old 09-17-2016, 04:24 PM   #11
PSP
Albany , California
Hi Cochese ; do you still have those lifters. I am interested in buying them.
Old 09-17-2016, 06:08 PM   #12
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
I have a few of those lifters I would sell. PM me
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 09-18-2016, 11:27 AM   #13
PSP
Albany , California
Hi shacks man
since I am a new poster the site won't let me PM you . My email is pospisilpaul@gmail.com
send me an email
thanks
Old 09-19-2016, 02:53 AM   #14
Am interested in purchasing one of your Hehr roof vent lifters if possible. If you still have one available, please let me know. (I've also considered just changing out my vent with a Fantastic Fan upgrade, but slipping a lifter in that works would be a much easier fix.)
Old 07-02-2017, 08:42 AM   #15
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Has anyone sourced the bracket with hinge that goes onto the dome to hold it down?
I finally got around to this and took off the old messed up dome. It is bolted through the
hinged bracket and the bolts are frozen with rust and sealant. Tried cutting them, heating them, no progress. Now I have an open roof no solardome on it...and of course its been raining here like crazy
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 07-02-2017, 10:22 AM   #16
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
WELL- Never mind..
I used a reciprocating saw with a smaller metal cutting blade and a vise. Got the bolts cleanly out.
Got to seal around the vent hole frame, put the lifter hinge in the vent and done!
Been on a list this week.
AIR #005
retired!
1978 Argosy crank up vent problem. Uncle Jack Roof Vents, Skylights & Fans 1 05-20-2007 02:17 AM
Vent Crank assembly 1970...inside trim happydaze Roof Vents, Skylights & Fans 0 05-06-2006 02:58 PM
Vent crank assembly milesvdubber Roof Vents, Skylights & Fans 5 09-13-2005 03:27 PM
Front vent won't crank down mavapa Roof Vents, Skylights & Fans 6 09-28-2004 04:18 PM
Ceiling vent crank handle Sneakinup Roof Vents, Skylights & Fans 4 12-02-2003 07:09 PM
