Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Roof Vents, Skylights & Fans
Old 03-16-2011, 05:23 PM   #1
vintageair's Avatar
1955 16' Bubble
Europe , glous
50's Hehr roof vent lifter arm rivet tool
Hello,
I needed help locating a tool for crimping the rivets that attached the LaDeau style lifter brackets to the vent
I've never used a tool like this before and hoping someone can help with this level of detail.
Whatever it is, it leaves a small dimple on the end of the rivet stem.
It also seems to be used to attach the hehr standard bars to the frames.
Thanks.
Sam
WBCCI #1234 Nebraska - My trailer is the #1
www.vintageairstreams.co.uk
https://twitter.com/carryonglamping
www.99point7percentpure.blogspot.com
vintageair is offline   Reply With Quote
Old 03-16-2011, 05:31 PM   #2
vintageair's Avatar
1955 16' Bubble
Europe , glous
pictures of front and back attached
can anyone point me in the right direction?
Name:	Screen shot 2011-03-16 at 23.29.33.png
ID:	124658   Click image for larger version
Name:	Screen shot 2011-03-16 at 23.29.42.jpg
Sam
Old 03-16-2011, 06:01 PM   #3
BradS's Avatar
2006 22' International CCD
1957 26' Overlander
Plymouth , Minnesota
Images: 14
I have been using tinners rivets for that type of repair. Its a flat rivet and you hammer down the small end
My 57 Overlander thread ( Holly is her name)
https://www.airforums.com/forums/f97/...eak-62257.html
"Life itself is the most wonderful fairy tale"
(Hans Christian Andersen)
WBCCI 10289
TAC MN-69
AIR 11240
BradS is offline   Reply With Quote
Old 03-17-2011, 02:18 AM   #4
vintageair's Avatar
1955 16' Bubble
Europe , glous
squeezing versus bucking?
Thank you, I have noticed these tinners rivets.
I have a feeling these original rivets have been squeezed rather that bucked. I think in some cases a more failsafe method of fitting them.
Attached is a squeezing tool i found. I wonder if there have been an previous posting regarding using this to tool to get the original detailing around the windows and ventings.
regards,
Name:	Screen shot 2011-03-17 at 08.13.43.png
Sam
Old 03-17-2011, 02:21 AM   #5
vintageair's Avatar
1955 16' Bubble
Europe , glous
link to aircraft site with the adapted clamping pliers for dimpling
Liming 801 Tools
Sam
Old 03-17-2011, 06:32 AM   #6
Images: 59
Those are called tubular or semi-tubular rivets. Search for semi-tubular rivet clinching tools.
Here is one guys DIY solution.
Old 03-17-2011, 06:46 AM   #7
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
Contact Steve at www.vintagetrailersupply.com . He has really nice rivet squeezers that will do this job perfectly.
Colin
Colin H is offline   Reply With Quote
Old 03-17-2011, 08:23 AM   #8
arodriguez60's Avatar
2008 27' Classic FB
1959 22' Flying Cloud
fairview , New Mexico
Images: 85
Kind of looks like a brake ling rivet tool wood work. Check with Rivets from Aircraft Spruce
Avion C11
1959 Flying Cloud
1969 Tradewind
1973 Safari
1983 34 ft Limited
2004 F250 superduty ext cab
2014 F350 longbed superduty crewcab
arodriguez60 is offline   Reply With Quote
Old 03-17-2011, 12:07 PM   #9
vintageair's Avatar
1955 16' Bubble
Europe , glous
thank you
thanks guys,
I have contacted steve to ask if can supply the dimple dies to go along with the squeezer he has for sale (very good price)
many thanks again.
sam.
Sam
Old 03-17-2011, 12:31 PM   #10
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Cool thread. I always wondered about those kind of rivets.
1958 Overlander
2011 Wolf Creek 850N TC
4CU 1st VP
mello mike is offline   Reply With Quote
Old 03-17-2011, 12:33 PM   #11
2008 27' Classic FB
Images: 85
aircraft spruce does have the dimple dies for the squeezer. and they have a good assortment of different squeezers at great prices.
Avion C11
1959 Flying Cloud
1969 Tradewind
1973 Safari
1983 34 ft Limited
Old 06-29-2011, 01:08 PM   #12
vintageair's Avatar
1955 16' Bubble
Europe , glous
Many thanks,
Bought the squeezer from VTS but they only have dies for the standard body rivets.
Will give Aircraft Spruce a call. It's the dimple on the back end I'm finding tricky to get.
Many thanks,
Sam.
Sam
Old 06-29-2011, 01:37 PM   #13
vintageair's Avatar
1955 16' Bubble
Europe , glous
Help!
Has anyone reinstalled the hehr window bars and or roof vents using small, solid rivets that have been squeezed and dimpled?
If so, I would do with a few pointers in the right direction -
VTS, don't do dimples, just flush plates.
Aircraft do but only have 1/8th receiving plates.
Aircraft Tool Supply | DIMPLE PUNCH (5/32" AN426 x 1/2" L) | 4265P-4
Regards,
Sam.
Sam
Fitting a Nicro vent to the existing Hehr vent Globie64 Roof Vents, Skylights & Fans 8 03-17-2011 02:35 PM
Shorten crank on roof vent? Breadbug Roof Vents, Skylights & Fans 4 01-31-2011 09:43 PM
Replacing center roof vent in a '79 blickcd Roof Vents, Skylights & Fans 1 01-29-2011 04:58 PM
