Old 01-25-2009, 08:40 PM   #1
MonkeyMudd's Avatar
Hart , Michigan
18 inch vent cover for Avion? Used?
I have an Avion with the 18 inch roof vents that needs a cover. Does anyone have this odd ball size laying around or know someone who does? Cayo wants over $100 for one, which is 1/10 the value I paid for the whole trailer! Is there anyone who could make one? Any help would be greatly appreciated.
Adam
1974 28' Avion LeGrande
Silver Lake Sand Dunes
www.reo-campwagon.blogspot.com
MonkeyMudd is offline   Reply With Quote
Old 01-27-2009, 03:37 PM   #2
Kevin245's Avatar
Hey Adam,
They are not readily available like the standard size units. I haven't found a price less than $90.00. So you're price seems to be in the ballpark. There are a couple of forum members who know about Avions, far more than I do. Maybe they can shed some insight.
On the bright side...At least you'd be keeping things original.
I recently purchase two 2'x 2' squares of 0.80" aluminum that I hope to use to make replacement covers from. The plastic on one vent cover is starting to degrade, and like you I was hoping to come up with a replacement solution. My efforts will not be cheaper than buying new ones, but my hope is that the aluminum ones will give me greater service life.
Regards,
Kevin
Eleanor Roosevelt
Old 01-27-2009, 06:37 PM   #3
Adam
Please recheck the dimensions of the vent flange that's riveted to the roof.
Most ceiling vent covers are 14" x 14".
Airstream did use a 14" x 26" from 1971 and prior.
Old 01-27-2009, 10:31 PM   #4
MonkeyMudd's Avatar
Hart , Michigan
Andy,
Its an Avion. Their standard roof vents were 18" square. The total width to fit the hole is something like 21" overall. The fan itself in them is almost 14" in diameter. I can fit through the opening.
Adam
Old 01-28-2009, 05:22 AM   #5
JimGolden's Avatar
1977 31' Excella 500
The front vent cover on my 34 footer is cracked and needs replacing as well. I was thinking of replacing the entire assembly with a Fantastic Fan. I've never actually measured it, though, so will take your word that it's 18" square. I didn't think it was that big, but maybe so. Anyway, if I didn't want to pay the $100 to Cayo, I'd just fabricate one out of aluminum. I'd probably paint it white on top and glue rigid foam insulation to the inside. Only downside is that it won't be translucent so it'll be a little darker.
Good luck.
- Jim
JimGolden is offline   Reply With Quote
Old 01-28-2009, 07:48 AM   #6
Silverhobby's Avatar
1967 26' Overlander
1968 30' Sovereign
Mosheim , Tennessee
The vents Avion trailers used are indeed 18" X 18" and I have a few. Please contact me by PM. The ones I have are fiberglas and are non transparent. These are well made and will last. I do not have any hardware for these vents.
Kevin
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Old 01-29-2009, 11:21 AM   #7
Adam
Would this help you? It's mounting is 18" X 18", and has a thermal barrier.
http://www.inlandrv.com/catalog/imag...0-skylight.jpg
Old 01-29-2009, 11:29 AM   #8
1967 26' Overlander
1968 30' Sovereign
Mosheim , Tennessee
Andy, The roof vent you have looks very similar but the cover for the Hammond vent is rounded in the corners. Thanks
WBCCI 17109
Old 01-29-2009, 11:39 AM   #9
Our square corner covers work ok with the radius flanges.
We have supplied them to Airstream owners for years.
When the square is opened, it provides more "tenting" than the radius corner covers, should it start top rain.
If it's fastened to the roof, then it doesn't matter.
Vent Cover - Lundeen Zed2 Roof Vents, Skylights & Fans 3 05-16-2009 04:43 PM
anyone tried this vent cover? gparker Roof Vents, Skylights & Fans 5 05-11-2008 03:42 PM
Broken vent cover? IRV Roof Vents, Skylights & Fans 15 10-14-2006 04:52 PM
Bathroom vent fan - 6 inch round Lee Davis Roof Vents, Skylights & Fans 8 08-23-2005 09:32 AM
