Old 07-16-2013, 11:28 AM   #15
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Originally Posted by Lumatic View Post
Glass is also more scratch resistant.
That's the problem with Lexan; you can hit it with a hammer without breaking it, but you can scratch it with a dry paper towel.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 07-17-2013, 05:15 AM   #16
2013 20' Flying Cloud
Cream Ridge , New Jersey
Originally Posted by tlsmit1 View Post
My only hesitation with a rock guard is visibility. Right now, when towing, I can see straight through the trailer and get a pretty good look at traffic behind me. I'd like to keep that ability if I can.
Your rock guard can be made of clear Lexan. I use Novis #1 to clean and polish the Lexan windshield on my boat. It works best with a soft cloth. I am happy with the results.
Joe Palmieri is offline   Reply With Quote
Old 07-17-2013, 05:51 AM   #17
1981 31' Excella II
New Market , Alabama
Lexan is alot more prone to cracking than most people think. Alcohol is not good for it. The ammonia based cleaners probably have a little alcohol in them. Vinegar is probably safe. Sometimes cutting it or drilling holes in it will make it crack. Especially if it has been sitting around for a while. We make bullets out of it where I work and we have problems with it cracking.
Perry
Old 07-17-2013, 07:30 AM   #18
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
IMHO a Lexan rock guard to protect a Lexan window is like wearing a belt and suspenders.
Old 07-17-2013, 08:58 AM   #19
tlsmit1's Avatar
1962 24' Tradewind
Saint Louis , MO
I think that the suggestion was meant to be a Lexan rock guard for a glass window, which would preserve my ability to see through the trailer while towing.
tlsmit1 is offline   Reply With Quote
Old 07-17-2013, 11:50 AM   #20
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
I have seen people use a flat tinted Lexan for the stone guard on the front window. It gives nice shade when tilted up and still allows a little see through.
Old 07-17-2013, 02:38 PM   #21
68Streamline's Avatar
Cerritos , California
If you chose glass I recommend using protective film to increased shatter resistance. Some will also give you energy saving year round (cooling/heating). I personally recommend tinted Lexan. It offers all of the above benefits plus its easier to work with.
68Streamline is offline   Reply With Quote
Old 07-17-2013, 03:17 PM   #22
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
I used Lexan on the side windows several years ago bought from Home Depot.
Has not yellowed or any problems.
However; you do need to pay attention on "this side out".
I cut it with a jig saw using a fine metal blade going slow so not to heat it.
Garry
Old 10-02-2013, 04:39 PM   #23
1979 23' Safari
Las Cruces , New Mexico
Lexan for an Argosy
I just got back from my local glass shop after checking on availability of Lexan. My '78 Minuet has a Pano wrap window vacancy that needs to be filled and short of finding a salvaged original I have decide Lexan is the best option. I will make an exact patten out of thin lexan from Lowes and then the local shop will use that as a pattern to cut the Lexan to the final shape...about $120. The local shop has 1/8 and 1/4 available. the "C" channel in the frame is about 5/16 and in the remaining windows it appears they use some type of gasket to seat the Lexan/glass into the frame. That is still on my list to search out. Also my search has indicated that judicious use of a heat gun at 300 degrees to bend the Lexan and constructing a form the shape of the frame to clamp it to as it cools, should help.
The again.........
Greg
apltrez is offline   Reply With Quote
