Old 02-12-2013, 11:05 AM   #1
1974 29' Ambassador
1976 25' Caravanner
trenton , Missouri
wing window tie bar
The seveice manual says the tie bar to the wing window must be replaced with a new one after removal. Any particular reason why?
bimpy is offline   Reply With Quote
Old 02-12-2013, 11:16 AM   #2
1981 31' Excella II
New Market , Alabama
What is a tie bar? There is a U-shaped frame and then a vertical section.
Perry
Old 02-12-2013, 11:22 AM   #3
1974 29' Ambassador
1976 25' Caravanner
trenton , Missouri
This is the vertical bar between the front window and the wing window. I have not completely removed it yet, I just drove it down about an inch with a hammer and block of hard wood
Old 02-12-2013, 11:26 AM   #4
1981 31' Excella II
Unless you totally trash it, I can't see why you would need to replace it. I doubt you can find just that part anymore. You would have to buy a new widow to get that part new. I have not seen window frame extrusions any place. Both my front wing windows were leaking around the outside gray gasket. I cut that outer flange with a utility knife and sealed with Trempro-635. I have no more leaks. I don't have much moisture between the panes yet. Why are you pulling the window?
Perry
Old 02-12-2013, 11:32 AM   #5
That bar, according to Airstream, holds the wing windows to the front window.
Interesting enough, that same bar "IS NOT": used to hold the wrap windows, which are much larger, to the front window.
We have found using that bar is a 100 percent waste of time and effort.
Using Vulkem sealer, does a much better job, especially when your fitting a new wing window into a 30 or 40 year old Airstream.
Old 02-12-2013, 11:33 AM   #6
Perry
Perry.
That "bar" is still available as a separate part.
Old 02-12-2013, 11:35 AM   #7
1974 29' Ambassador
1976 25' Caravanner
trenton , Missouri
The wing windows leak and I am going to remove the inner pane and the ugly gasket in between. (I have moisture here) These are called splice bars at ODMRV and are only $6.00 each.
Old 02-12-2013, 12:01 PM   #8
1974 29' Ambassador
1976 25' Caravanner
trenton , Missouri
Thanks Perry and Andy. Andy can you give the exact part # for the olympic rivet to use for the window frames?
Old 02-12-2013, 12:16 PM   #9
Olympic rivets are part # 28100 for a bag of 100.
You will also need one tube of Vulkem sealer.
Old 02-12-2013, 01:41 PM   #10
Snedwid's Avatar
2011 23' FB Flying Cloud
Perry , Florida
Pic's pic's please so I can get up to speed here :-)
"If you don't know where you are going, you will wind up somewhere else." Yogi Berra
Snedwid is offline   Reply With Quote
Old 02-12-2013, 02:03 PM   #11
Pictures of what??
