Old 06-21-2010, 09:39 AM   #1
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
Wing Window Leaks
From my inspection of a removed wing window, it appears there are four possible leak paths. The frame seen edge-on looks something like this:
Name:	wing window.jpg
Three of the leak paths are shown in light blue, which assumes for two of the paths that the vinyl gasket has some hidden rips inside the frame. It also assumes that the "goop" between the panes has failed in one or more spots.
The fourth path is through the corner joint. The frame is in four pieces--the curved piece (which is one continuous extrusion for each part), which has an outside and inside part, and the straight edge, which also has an outside and inside. The two corner joints could possibly allow water to get in between the inside and outside frame pieces.
Name:	P1000090 outside corner-s.jpg
ID:	105293 Click image for larger version
Name:	P1000096 inside corner-s.jpg
The above photos show the outside and inside of a corner joint. There is still a lot of crud on the frame from when it was removed.
You can see that the outside part is definitely a separate piece of metal, but even with the screws removed from the back, it wouldn't budge.
Name:	P1000095 putty knife-s.jpg
Thhis makes me think that it's possible the drawing above is slight in error, that the "outside" piece actually wraps around the two panes, and then is just retained in the "inside" frame by the screws. This would allow the window to be removed without removing the inside piece that's riveted to the shell.
Name:	wing window 2.jpg
If anyone has disassembled a wing window, can you confirm which drawing is correct?
These windows leak --- like a sieve. I've had up to three inches of water inside them. The problem is that three of the leak paths are improbable--they require at least three failures: the gasket contact with the frame, the goop, and the gasket inside the frame has to be ripped. I've sealed the outside edge of the glass and still had major leaks. Where the heck is it coming in?
Zep
Old 06-21-2010, 10:19 AM   #2
elfirebob's Avatar
2007 25' International CCD FB
1970 23' Safari
1956 16' Bubble
Jamul , California
Images: 159
May be doing this project soon.
Zep,
Found a donor rig and get my two replacement wing windows for my '70 Safari. As I have to pull all my parts, I'll let you know what I find, pics and all...
I ordered my rivets, tools and "goo" online this week and should start pulling my "other" lower oval windows off next week. As a Rally Warrior, I think I can pull both the projects off!
Thanks for your insight, postings and tech...
Bob U-
Stream Safe,
Bob U-
San Diego, CA.
The " TinDen "
2007 25' International FB
1970 Safari 23' Land Yacht
1956 Bubble 16' California Whale Tail
Charter Member 4 Corners Unit
(View all of elfirebob's images)
elfirebob is offline   Reply With Quote
Old 06-21-2010, 10:29 AM   #3
dscluchfc's Avatar
1984 31' Excella
Abernathy , Texas
On my wing windows, I used a knife to cut the gasket out on the outside between the frame and glass. I filled the cavity with Vulkem Sealant to make it resemble the old cut out gasket.
I scraped out the seam around the window between frame and trailer, and filled it with Vulkem Sealant.
I mashed Vulkem into the corner seams manually and cleaned up.
No more leaks.
David
TAC # TX-18
AIR # 410
http://www.flickr.com/photos/dsphotoscapes
dscluchfc is offline   Reply With Quote
Old 06-21-2010, 12:04 PM   #4
1975 31' Sovereign
1977 23' Safari
I mashed Vulkem into the corner seams manually and cleaned up...
I did essentially the same thing, not quite as complete as you, but they still fogged up and leaked perceptable amounts of water. I was glad to get rid of them.
Zep
Old 06-21-2010, 02:57 PM   #5
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
I have one already dissasembled at home. When I get back from this sim session I'll take a look at it. Man we got humbled today, had multiple failures from the very begainning.
Wing Window replacement Zeppelinium Windows & Screens 16 01-27-2011 06:16 PM
wing window weatherstrip/sealer mickeymoose Leaks - Weatherstrips, Gaskets, Caulks & Sealants 0 05-18-2010 09:00 AM
Curbside Wing window and window by door L&R Rock Guards, Segment & Window Protectors 5 07-07-2009 10:45 PM
wing window aquarium HELP!!! Reg Windows & Screens 1 09-02-2006 10:23 AM
Water in Wing Window! Navigator Windows & Screens 9 01-03-2004 09:07 AM
