Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Windows & Screens
Old 05-21-2015, 11:37 AM   #1
Guyton , Georgia
WING WINDOW - Broken inside pane
WHAT ARE MY OPTIONS? I really don't want to remove the entire window frame from the camper unless I have to.
Can I simply remove the shattered glass from the inside and only have a single pane window on the curb side?
What other options do I have? can I replace the inner pane of glass without having to remove the frame from the camper?
any advice would be GREATLY appreciated
Thanks!!!
Walter122795 is offline   Reply With Quote
Old 05-21-2015, 02:16 PM   #2
aquinob's Avatar
Portsmouth , Virginia
If you can get the glass out then no, you dont have to remove the frame. If you want to replace the glass than yes, you do remove it. Its a poor design, you can never really seal it up so it doesnt leak. I removed the inner panes on my 73 Overlander, I dont think it will make much difference with heating or cooling but looks better for sure.
Ongoing adventures at:
https://1973overlander.blogspot.com/
aquinob is offline   Reply With Quote
Double pane to single pane window conversion ronstory Windows & Screens 8 10-07-2017 06:38 AM
How do you separate the front double pane wing window Debnw Windows & Screens 8 04-05-2016 09:59 PM
Source of gasket for double pane to single pane conversion? Taylormade Windows & Screens 5 04-05-2016 08:07 PM
Two Piece, Double Pane, Wing Window Repair Tom Nugler Windows & Screens 7 04-05-2016 04:37 PM
