Old 10-27-2011, 08:18 AM   #1
1981 31' Excella II
New Market , Alabama
Windows won't lock open
I have one of two windows that don't want to lock open. I am assuming that the little Nylon piece has a tit that engages the holes in the window track? So I need a new Nylon piece for each side?
Perry
Old 10-27-2011, 08:20 AM   #2
Perry
Your describing the "deluxe" window arms.
Sorry, but those are history and no parts are available,
Old 10-27-2011, 08:46 AM   #3
1981 31' Excella II
Well there must be a fix. Mine is only 30 yrs old and is just a baby compared to some on here. I can make a new piece from scratch if need be. I am assuming it is the Nylon piece that is a wear item that needs to be replaced?
Perry
Old 10-27-2011, 08:53 AM   #4
Aluminum Falcon Mechanic
Darkspeed's Avatar
1972 31' Sovereign
Wesley chapel , Florida
Photo?
Darkspeed is offline   Reply With Quote
Old 10-27-2011, 08:54 AM   #5
Perry
Perry.
Airstream at one time, kept parts for 30 to 40 year old Airstreams.
That took up considerable warehouse space.
Airstream has down sized the parts warehousing twice of the past few years, that I know of.
However, in their defense, they still keep some parts going back even to the 1969 models.
The small parts, such as you need, can take up gobs of storage space, and really don't add but a very little to the bottom line.
The space that was used for many of the older parts, is now used to produce various parts for the current production line.
I will take a peek at that nylon part and will get back with you, as to a possible answer.
Old 10-27-2011, 08:58 AM   #6
1981 31' Excella II
It is supposed to rain the next couple of days so I will have some time to take photos of these things. I will try to post some tonight.
Perry
Old 10-27-2011, 11:49 AM   #7
Perry
Perry.
That "nylon" slider should not be hard to make.
I will check into it, when I have some time.
Old 10-27-2011, 11:52 AM   #8
Perry
Airstream did have that "block" back in the 80's, but they no longer do.
Old 10-27-2011, 12:37 PM   #9
c_lewis77's Avatar
1982 34' Limited
Brunswick , Georgia
Images: 22
Perryg114:
I have an '82 with similar window hardware to what you are describing. I have replaced the front window with lexan and it is non operable. All of the hardware is still there, if those pieces match what you need and if can get them off with out breaking, you can have them.
1982 34' Limited
2000 Excursion V10 4x4
WBCCI #3321
TAC #GA-24
c_lewis77 is offline   Reply With Quote
Old 10-27-2011, 01:19 PM   #10
1981 31' Excella II
Let me get mine apart and see what is what.
Perry
Old 10-27-2011, 07:47 PM   #11
1981 31' Excella II
Ok here is a photo of the mechanism and I believe the part that engages the holes in the window frame is the Nylon piece and in my case I am guessing there is a pin in the Nylon piece that engages the window track that has holes in it. My window won't stay open so I am assuming the pin has worn away.
Perry
Old 10-27-2011, 07:56 PM   #12
c_lewis77's Avatar
1982 34' Limited
Brunswick , Georgia
Images: 22
My hardware is exactly like that. I have found that pushing the arm to the window side helps it catch. I have 1 window that does not cooperate at all; I unlatch from the inside and open/secure from the outside. It is a PITA but it works
1982 34' Limited
WBCCI #3321
TAC #GA-24
Old 10-27-2011, 07:59 PM   #13
1981 31' Excella II
My bathroom window catch is completely worn out. Sometimes you can bend things enough for it to stay open for a short time but the catches are gone. I need to replace some gaskets anyway so I will check things out then.
Perry
Old 10-27-2011, 08:03 PM   #14
c_lewis77's Avatar
1982 34' Limited
Brunswick , Georgia
Images: 22
Funny, it is my bathroom window that I have to secure from the outside. I push the nylon tabs in by hand from the outside.
1982 34' Limited
WBCCI #3321
TAC #GA-24
Door lock issues carlvs Doors & Locks 4 05-09-2011 07:57 AM
Lock trouble on 1961 AS Ambassador... help please. 61Ambassador Doors & Locks 13 04-21-2011 02:06 PM
Xena Lock With Alarm For Hitch Coupler wjk Hitches, Couplers & Balls 8 04-13-2011 06:27 AM
Modifying a Fastec door lock jeffkraft200 Windows, Doors, Locks & Vents 12 03-26-2011 03:02 PM
'73 Tradewind Windows Vista and Front Sides constructor Windows & Screens 8 01-28-2011 05:44 AM
