Old 10-27-2011, 08:10 PM   #15
1981 31' Excella II
New Market , Alabama
Well the bathroom window is the one that is opened and closed the most to dry the place out.
Perry
Old 10-28-2011, 03:47 PM   #16
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Perry
And a big/heavy window on top of that, in most cases.
David
Old 10-28-2011, 07:38 PM   #17
Aluminum Falcon Mechanic
Darkspeed's Avatar
1972 31' Sovereign
Wesley chapel , Florida
By the ware marks in the track I would guess the pin is not plastic.
Darkspeed is offline   Reply With Quote
Old 10-29-2011, 06:26 AM   #18
1981 31' Excella II
This is one of the tracks that works. I could not get to the one that is broke with the camera. I am just trying to show the piece that is suspect. I will try to pop that widow out today and see what is broke.
Perry
Old 10-29-2011, 08:15 AM   #19
Perry
Perry.
You can see the back side of the "pin" in your photo.
The white or black nylon piece, is nothing but a slide, since the round pin engages the round holes that you can also see.
The pin, is what is worn out.
Old 10-29-2011, 08:23 AM   #20
1981 31' Excella II
I can probably put in a new pin. It looks like it is riveted in there either that or it is pressed in.
Perry
Old 10-29-2011, 08:30 AM   #21
Perry
That pin is pressed in.
Old 10-29-2011, 08:33 AM   #22
Darkspeed's Avatar
1972 31' Sovereign
Perry
Perry it may be as simple as slightly rotating the pin so an unworn edge engages the hole. Depends on if it was machined with a slope.
Old 10-29-2011, 09:04 AM   #23
That pin has a flat surface that protrudes from the window lift arm. No taper at all.
I will see if it will rotate when I get back to the office.
Old 10-29-2011, 01:35 PM   #24
1981 31' Excella II
Ok well the problem is fixed. The pins were frozen in the Nylon block so they would not engage the track. Also the handles were bent such that they were holding the pins away from the tracks. Bending the handles toward each other made it possible to push the pins into the holes in the track after I lubed everything with spray lithium grease. It is hard to get to the handles in the center bath because the window is behind a mirror and it is very narrow in there. I need to lube the rest of my windows. I think this trailer sat neglected for the last few years. I think if it sat another 5 yrs it would have been info the full Monte Restore. I think I saved the old girl just in time.
Perry
Old 10-29-2011, 02:43 PM   #25
Perry
Great.
Yes, it's always wise to keep parts lubed with silicone spray.
Saves many headaches.
Door lock issues carlvs Doors & Locks 4 05-09-2011 07:57 AM
Lock trouble on 1961 AS Ambassador... help please. 61Ambassador Doors & Locks 13 04-21-2011 02:06 PM
Xena Lock With Alarm For Hitch Coupler wjk Hitches, Couplers & Balls 8 04-13-2011 06:27 AM
Modifying a Fastec door lock jeffkraft200 Windows, Doors, Locks & Vents 12 03-26-2011 03:02 PM
'73 Tradewind Windows Vista and Front Sides constructor Windows & Screens 8 01-28-2011 05:44 AM
