Old 06-18-2006, 05:14 PM   #1
1979 31' Excella 500
Detroit Area , Michigan
Images: 43
Windows that stick
I have a 31' 1979 International. The two street side living room windows open easy enough but are always a bear to close with the handles. It gets really frustrating. Is it just a matter of re-greasing the channels on the outside to fix them or are there parts that wear out?
wacnstac is offline   Reply With Quote
Old 06-18-2006, 05:23 PM   #2
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
You can spray some WD40 in the locking camps to clean teh action, and then try and get some light grrease in there if necessary.
The bracket that receives the rotating latch might need a little help with a nail file, right where it tends to seize. Make sure that the spring loaded cam is free and clear, moving easily in and out of it's spring seat.
You can adjust the tension a bit as well, with the nut at the and of the cam bolt.
Uwe
www.area63productions.com
Old 06-18-2006, 05:43 PM   #3
Images: 43
My locking clamps work fine. It's the slide mechanism that hangs up somehow.
Old 06-19-2006, 05:26 AM   #4
Images: 43
BTW the windows slide up just fine, it's getting them to slide back down that is a real bitch.
Old 06-19-2006, 05:42 AM   #5
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
wacnstac,
I use silicone spray in the slides, I also have discovered that the if the arms are slightly bent they will bind. I had this issue with my rear bath window and fought with the b**ch for a couple of months before I finally figured out what was up. Also make sure it isn't binding on the screen openings, it can cause an odd angle on the arms and issues with closing. For some reason the worst of the binding occurs when you are attempting to close the window in a pouring rain
Aaron
WBCCI #XXXX AIR #2495
Old 06-19-2006, 06:38 AM   #6
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
If you can not get the arms perfectly straight and away from the aluminum guides which they might rub against, A little oil on the sealing brushes that keep the insects out, will oil the arms each time they are moved in and out. If you use a higher viscosity oil it stops the aluminum to aluminum siezing.
Old 06-19-2006, 06:52 AM   #7
Images: 43
Originally Posted by wahoonc
wacnstac,
Aaron
This is exactly what happened to me. It seems that you can always open the windows further but they get hung up closing them.
Old 06-19-2006, 02:44 PM   #8
Cracker's Avatar
Pittsfield , Maine
My sticky window problem is, I believe, limited to the late model trailers that have the awning windows closing against a rubber seal. The windows stick to the rubber seal, once the trailer has sat stored for awhile, and I normally have to go outside to manually free them up. I've found that baby powder, applied to the rubber seal, seems to eliminate the problem for some time - but maybe others have come up with a better solution???
Cracker
Cracker is offline   Reply With Quote
Old 06-19-2006, 03:29 PM   #9
1977 31' Sovereign
1989 34' Excella
People from the rubber industry use zinc stearate powder to prevent rubber from sticking to itself and other things. Any waxy fine grain parting agent will do for the sticky problem but I do not think that what the original poster was complaining about.
Wondering what kind of glass to use for replacing all windows in 1958 Traveller williamhenshall Windows & Screens 3 08-19-2007 07:15 PM
Water leak panoramic windows Andy Fay Windows & Screens 16 01-05-2007 08:33 AM
Windows Inland RV Center, In Windows & Screens 1 04-20-2004 06:14 AM
Vista View windows Charles Q Treichel Windows & Screens 10 01-18-2003 08:23 AM
Caravel windows susan martin 1966-68 Caravel 1 08-21-2002 08:43 AM
