Old 06-07-2007, 07:50 AM   #1
1952 21' Flying Cloud
1982 31' Excella
Milwaukie , Oregon
Windows on '52 Flying Cloud
I just got my trailer home. Before I had even seen it I was told windows were broken. No big deal. But what I found were two of the flip up windows and frames were removed. These are the double flip up windows, I don't know what they are called. Also the window I think they call a Jalouse is missing. all on the curb side. Does anyone know where to find these?
Brian
wander'n is offline   Reply With Quote
Old 06-07-2007, 09:57 AM   #2
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Brian
Brian,
I have been looking for two windows for my 1954 Liner, also. I am sure that they are the same type. If you find then let us know.
Bill
Just my personal opinion
Old 06-07-2007, 12:13 PM   #3
safari57's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
West Coast , BC
Send a message via MSN to safari57
In our search for the right Airstream for my buddy we ended up picking up a '52 Flying Cloud in Edmonds, WA. However, at Poulsbo we looked at a row of at least 20 silver trailers, mostly vintage Airstreams. He didn't realize that sitting on grass for well over 10 years would rot the frames out and on the one we had gone to see it was so bad you could break chunks off with your hand. I'll get the fellows email address and see if he's got any with the correct windows and if so if he's willing to sell parts. He may not want to do this, but I think he was starting to realize that some of his units were now at a parts only stage. If you want, I can at least ask. Let me know, and also which windows it is that you require. He also knows where several others are in the area so he may be able to come up with something. I'm not sure of his willingness to do this, but he does sell a lot of other vintage stuff on eBay so if there's a buck in it for him...................
Another thought, have either of you taken your rig, or a window, to a local glass shop to see if they could replicate what it is you need? The older guys in particular are generally pretty good at this stuff. It might mean a trip to a sheet metal shop to have the frame made, then the glass shop, and the guys at the glass shop may have some recommendations as to who to use.
Barry
safari57 is offline   Reply With Quote
Old 06-07-2007, 12:20 PM   #4
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Barry
Barry,
Thanks for checking, the window frame I need is in post 10 of this thread: http://www.airforums.com/forums/f334...r-17291-3.html It never occured to me to check with a sheet metal fabricator, but it might work.
Bill
Old 06-07-2007, 01:07 PM   #5
WHR
1981 24' International
1967 17' Caravel
West Richland , Washington
52 Flying Cloud Parts
Barry - I would like to follow up on an address of the fellow in Poulsbo. I have a 53 Cruiser that Pam and I are restoring in Eastern Washington. We are looking for a gaucho couch for the front living area. Any help would be appreciated. Thanks Wade.
WHR is offline   Reply With Quote
Old 06-07-2007, 01:21 PM   #6
1982 31' Excella
Milwaukie , Oregon
windows
Thanks Barry. I would love to talk to the guy. By the way I said curb side in my original post but it is the street side the windows are on. I didn't' even think of sheet metal shops remaking the frames. I could check that out. But if I could get exact replacments I would like that more.
Brian
Old 06-07-2007, 03:09 PM   #7
1953 Flying Cloud
1953 Flying's Avatar
1953 21' Flying Cloud
West Sacramento , California
Images: 8
window
Hi wander'n,
I have a 53' Flying Cloud. Are looking for the outside frames or the inside frames? And are you sure your windows are Jalouse and not Hehr. If they are Hehrs and your looking for the inside frame, I rebuilt mine.I'm trying to attached a photo but it's not working. I will try again when I get home.
1953 Flying is offline   Reply With Quote
Old 06-08-2007, 07:49 AM   #8
1982 31' Excella
Milwaukie , Oregon
frames
The windows I need are the inside frames. They are Hehr but also the window over the sink appears to be different. The 2 frames are gone so there is nothing to rebuild. I was hoping to find replacements.
Brian
Old 06-08-2007, 08:03 AM   #9
CaptainJones's Avatar
Western , Kentucky
I have been looking for windows over 1 1/2 years. They are few and far between. Good luck. If you find any extra let me know.
Greg
Greg Jones
CaptainJones is offline   Reply With Quote
Old 06-08-2007, 05:40 PM   #10
1953 Flying Cloud
Images: 8
Brian
If the windows are any thing like mine. All the inside frames are built the same. L shape with a little u shape at the top. 4 pieces left , right, top and bottom. The corners on the bottom part were cut off at an angle. I was able to make them with some .032 aluminum and a right angle grinder for cutting. The u part was a little tricky. We just left about 1/8" extra at the top and bent in over with a pair of pliers. Drilled holes were needed and inserted new screws and nuts. Which I purchase from www.vintagetrailersupply.com. I hope this helps
Old 06-08-2007, 05:57 PM   #11
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Originally Posted by 1953 Flying
If the windows are any thing like mine. All the inside frames are built the same. L shape with a little u shape at the top. 4 pieces left , right, top and bottom. The corners on the bottom part were cut off at an angle. I was able to make them with some .032 aluminum and a right angle grinder for cutting. The u part was a little tricky. We just left about 1/8" extra at the top and bent in over with a pair of pliers. Drilled holes were needed and inserted new screws and nuts. Which I purchase from Vintage Trailer Supply - Vintage travel trailer parts and supplies!. I hope this helps
Glad that you were able to fabricate the inside frame. I am missing the part which the glass fits into, more difficult if not impossible to fabricate.
Bill
Old 06-09-2007, 09:13 PM   #12
safari57's Avatar
1960 24' Tradewind
West Coast , BC
Bill
Bill,
You might want to try a local sheet metal shop. It's surprising what they get into building. My wife drove me over to one of the local "older" RV repair places today and I queried about old windows and he had none. I've fired off an email to the fellow in WA with all the trailers to see if he's got anything, and if so, if he's willing to part any out, but so far no response.
Barry
Old 06-10-2007, 10:47 AM   #13
1982 31' Excella
Milwaukie , Oregon
Barry. Thanks for e-mailing the guy in Poulsbo. Hope he replies. Sounds like a wealth of parts there. I also left an e-mail at Timeless Travel Trailers. The work I saw on there site looks great. I asked if they would be interested in remaking the frames I need.
Here is some pic's from the trip back. I will post more of the inside later.
Name:	KS TRIP 008.jpg
ID:	38902   Click image for larger version
Name:	KS TRIP 009.jpg
Name:	KS TRIP 012.jpg
ID:	38904   Click image for larger version
Name:	KS TRIP 013.jpg
Old 06-10-2007, 10:42 PM   #14
safari57's Avatar
1960 24' Tradewind
West Coast , BC
Sure looks like a sweetheart trailer. I'm sure it towed like it wasn't even there. When we brought my buddies back from Edmonds last week it was like it wasn't behind the truck.
What is that just below the middle window on the street side? Is it a water fill?
Barry
