Old 02-12-2003, 09:50 AM   #1
scootertrash's Avatar
Windows
We have recently acquired a '68 Overlander, the front window has been replaced with a piece of plexi-glass and we want to restore this to a glass window. My question: is the front window the same as the rear in that it is flat with no frame. thanks, John.
scootertrash is offline   Reply With Quote
Old 02-12-2003, 10:25 AM   #2
New Borockton , Alabama
Images: 21
John,
My 68 has the frames on all of the windows. Maybe your rear has already been replaced with the frameless type. Are your side windows framed? Inland has the frames.
Randy
Old 02-12-2003, 11:50 AM   #3
Overlander;
My '68 has frames on all of curved side windows but the rear has the three bottom latching clips attached directly to the glass. I don't know enough to know if this is correct or not. Thanks, John.
Old 02-12-2003, 12:01 PM   #4
Images: 21
John,
I think your rear window has been replaced. Check the lower left corner and see if it says "Corning". If not, it's probably not original and even if it does, it might be a replacement corning and they never bothered to put the trim back on.
Randy
Water leak panoramic windows Andy Fay Windows & Screens 16 01-05-2007 08:33 AM
Open your frameless windows wide? TomW Windows & Screens 17 08-23-2004 08:14 PM
Windows Inland RV Center, In Windows & Screens 1 04-20-2004 06:14 AM
Leaky Windows & Skin Replacement PizzaChop Leaks - Weatherstrips, Gaskets, Caulks & Sealants 9 03-08-2004 11:13 PM
Water leak beneath windows Ann Windows & Screens 3 08-02-2003 04:21 AM
