Old 09-15-2011, 06:16 PM   #1
goshawks00's Avatar
1966 22' Safari
1954 22' Flying Cloud
Saline , Michigan
Window woes --Need a track
When we bought our 66 Safari, the PO said he didn't use the side window by the goucho because it was broke. So now that I got a minute I took it a part to see what the problem is. Well.. the track that the glass fits in is all bent up... and while to two ends were still in the correct place the middle of it is hatcheted up. The window from is fine. I worked all day today .. well really only about 3 hours , but it seemed like all day , and haven't gotten anywhere. I am wondering if anyone knows where I could possibly find a track for this window? I hate to not be able to use it, and worse try to squeeze it in place only to break the glass that is in it. Help Please!!
Thanks ,
Barry & Karen in Mi.
goshawks00 is offline   Reply With Quote
Old 09-15-2011, 07:45 PM   #2
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Can you post some pics please...We can't see what you see.
http://www.airforums.com/forums/f138...tml#post612569
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 09-16-2011, 05:57 AM   #3
goshawks00's Avatar
1966 22' Safari
Saline , Michigan
test:
OK got picture thing figured out... I'll try and get a shot of the window frame... but really nothing to see.. I am asking here for a place to get a new upper window frame that the glass sits in... Being a 66 Safari there is no other supporting window frame for the glass edges.. . The piece I need is 39" long.
Old 09-16-2011, 06:18 AM   #4
1967 22' Safari
1960 Caravel
Images: 8
Originally Posted by goshawks00 View Post
test:
Parts for Corning windows are very hard to come by and new part are as scare as hens teeth.
A picture may help someone that has spare parts floating around.
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
Old 09-16-2011, 06:37 AM   #5
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
BE CAREFUL. That glass, like all tempered glass, will shatter when nicked or whacked at "just the right spot." No undue force either. Look in the search area and you will find info on 66 - 68 windows. If all else fails...check with Inland and Andy.
'58 Hehr Window - Is this the correct window operator replacement? mello mike Windows & Screens 22 10-08-2012 08:49 AM
AS280 - Front (driver) sliding window latch dalefox Classic Motorhomes 13 01-05-2012 06:41 PM
Rear window leak fixed! Really? I think so. 1964 GlobeTrottin 1960 - 1964 Globetrotter 0 04-30-2011 05:42 AM
Replace missing front window with jalousie? Cruisette Windows & Screens 6 03-31-2011 04:23 PM
Need curtain track photos circa '79 blickcd Upholstery, Blinds, Walls & Interior Finishes 5 01-11-2011 05:06 PM
