Old 03-13-2007, 05:09 PM   #1
pittsf's Avatar
1965 22' Safari
Washington, DC , Micanopy, FL
Window Weatherstrip Replacement
'65 Safari
Has anyone replaced their window weatherstrip, and if so, may I please have a reference to where you obtained the replacement material, and any special installation procedures?
I bought some last year that I've had a hard time getting installed, and it comes out. It looks and extrusion, that in cross section has two projections that need to be pressed into the weatherstrip channel.
Any information or suggestions would be greatly apprec1ated.
pittsf is offline   Reply With Quote
Old 03-14-2007, 03:16 PM   #2
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Originally Posted by pittsf
'65 Safari
Ordered mine from Oasis RV, they had it in stock.
Check Vintage Trailer too Vintage Trailer Supply - Vintage travel trailer parts and supplies!
Also, I have a Webpage that shows what I did
Weather Strip Maintenance
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 03-14-2007, 03:22 PM   #3
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
For a 1965, you will need the bulb seal, and also the glazing bead.
the bulb seal goes into a channel of the stationary part of the window frame, and the glazing bead seals the glass to it's frame.
their window page: Vintage Trailer Supply - Vintage travel trailer parts and supplies!
Uwe
www.area63productions.com
Old 03-15-2007, 10:42 AM   #4
'65 Safari
1965 and older trailers used a "bulb" gasket. A replacement is available, but is no better than the original, in that it takes a "set" very quickly and then will not properly seal.
Airstream from 1966 and into the late 90's used a double flare window gasket, that was far superior.
But, in time Airstream switched to a "D" shaped gasket that is hollow.
When compressed by the window, a seal is created that has no equal.
That "D" gasket is now being used by many owners from 1968 and down.
In the case of using it on a 1965, the "D" gasket can be attached with adhesive to the window frame, or the window jamb (the frame that is riveted to the shell).
The "D" gasket leaves the "bulb" type gasket, at the starting line.
Ask for a sample.
Old 01-15-2010, 03:41 PM   #5
Okiegent's Avatar
1983 31' Excella
Choctaw , Oklahoma
Images: 14
Andy will you show me a photo of this gasket and how it fits on the window or frame? I am in phone conversation with one of your sales people now about what to use on the window.Many thanks Andy.
Tom C.
Okiegent is offline   Reply With Quote
Old 01-15-2010, 04:33 PM   #6
Tom.
The flat part goes on the back side of the window frame, that's called a "sash".
It's an improved gasket for the opening windows.
http://www.inlandrv.com/catalog/imag...ndowgasket.jpg
Old 01-16-2010, 03:53 AM   #7
Okiegent's Avatar
1983 31' Excella
Choctaw , Oklahoma
Images: 14
Mine at present are on the window Andy. Then the window closes against the sash.Otherwise its attached to the glass. Thats why I wanted to make sure I got the right material. Do I need the D channel gasket? Many thanks Andy. Have a great day..
Tom C.
Old 01-16-2010, 05:09 AM   #8
Yes.
Oval Window Frame Replacement MikeMikeMI Windows & Screens 8 12-30-2007 10:49 AM
Curved side window replacement michel88 Windows & Screens 7 09-29-2006 09:20 AM
Window Replacement Jim Sease Windows & Screens 1 12-29-2002 07:05 AM
Window Frame Replacement Charles D. Bennett Windows & Screens 20 08-16-2002 06:03 PM
Acrylite Window Replacement Gordon Watt Windows & Screens 12 08-12-2002 08:46 AM
