Old 10-28-2006, 10:32 PM   #1
Dano57's Avatar
1979 31' Excella 500
Edmond , Oklahoma
Question Window Type??
Evening Folks,
I have a 79 Excella 500 and have some worn parts on some of the windows and as a result sometimes they are hard to unlatch when closing. I have seen a couple of different names used for the window mechanisms, what would ones in a 1979 be? You pull the handles inward to unlatch the arms allowing them to raise or lower.
Who or where is a good place for replacement parts? It looks like there are nylon blocks which have a round protrusion that fits into holes in an aluminum track. I think these are worn and loose on the operating arms.
Dan
Dano57 is offline   Reply With Quote
Old 11-18-2006, 09:23 PM   #2
Dano57's Avatar
Edmond , Oklahoma
Question
Thought I'd run this by everyone again. I have seen windows mentioned by the name of Hehr windows but from what I have seen mine are different. Anyone?
Dan
Under Renovation,
As yet to be towed!
Old 11-19-2006, 05:03 AM   #3
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Dan
Can you post a pic of what you have?
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 11-19-2006, 08:02 AM   #4
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Your wndows are the type used after 1969. Some of the components are still used on brand new trailers today, although with small changes.
A common failure on these windows were broken plastic window bars. Those attach to the sides of the window frame and hold the window open in three positions. Those parts are available from airstream dealers, or inlandRV.com
The two bottom window locks can usually be restored by cleaning and lubrication. They are spring loaded locking cams with chrome handles. Rubber window gaskets are still available.
Uwe
www.area63productions.com
Old 11-19-2006, 08:55 AM   #5
Dano57's Avatar
Edmond , Oklahoma
uwe,
The problem I am having is that the blocks (nylon maybe) seem too loose on some of the windows and as a result they hang in the track and I have to go outside and use a thin screw driver to release them. I also think that I need to replace many of the slotted pieces that the arm work through, some are broken and most have the fuzzy stuff gone. I'll call the dealers this week to try to locate, I have looked all over the net but haven't found any so I was worried that they were not available.
Thanks folks, I appreciate the help.
Dan
Under Renovation,
As yet to be towed!
Window latch dilemma maxandgeorgia Windows & Screens 5 05-18-2018 10:35 AM
1974 Excella front window docu post john hd 1973-1974 Excella 500 22 08-06-2004 01:53 PM
Front Wing Window Repair Charles D. Bennett Windows & Screens 0 08-10-2002 06:04 PM
outside window covers 83Excella Rock Guards, Segment & Window Protectors 2 06-30-2002 06:24 PM
Window Frame Removal 64GT Windows & Screens 4 04-09-2002 12:40 PM
