Old 04-04-2013, 05:41 AM   #1
1965 26' Overlander
Marion , New York
Window trim for '68 Overlander
Fixing up a 1965 Overlander. It has the usual leaks, etc. I need to replace some of the exterior trim on the windows.
Can anyone tell me what that trim is and where to get it?
65Overland is offline   Reply With Quote
Old 04-04-2013, 05:45 AM   #2
eljay's Avatar
1968 24' Tradewind
Rural, blink and you'll miss it , Missouri
May want to correct your thread title. Says "68 Overlander", completely different beast than the 65!
Not knowing enough to be afraid... (I know more than I did, but I did it anyway!)
Eljay
1968 Tradewind Double.
eljay is offline   Reply With Quote
Old 04-04-2013, 07:54 AM   #3
Trim doesn't stop water leaks.
But, the gaskets do.
Old 04-05-2013, 06:01 AM   #4
1965 26' Overlander
Marion , New York
Very true. I need the window molding trim for appearance and the gasket for water control.
Old 04-05-2013, 06:05 AM   #5
For what year?
You say 65 and 68.
Old 04-05-2013, 06:05 AM   #6
1965 26' Overlander
Marion , New York
New to posting threads. How do I get back to the thread title to change it?
Old 04-07-2013, 05:28 AM   #7
1965 26' Overlander
Marion , New York
Andy,
I appreciate your help...it really is for a 65 Overlander. I have applied for a thread title change.
What would be the common source for a water leak by the window next to the door? I have noticed that the window frame is cracked and loose at the corner. From what I understand this is common and discussed in several threads on this site. Could this allow a lot of water to enter the trailer?
Thanks for our help.
Old 04-07-2013, 09:41 AM   #8
Andy,
Sealers and more sealers.
Use Parrbond for small seams and Vulkem for large seams.
Change the window sash gaskets from the hollow tube original to the new style "D" gasket.
Use the "D" gasket on the entrance door as well.
Old 04-14-2013, 02:44 PM   #9
1965 26' Overlander
Marion , New York
Thanks Andy. Where do you purchase Vulkem? And what is it exactly?
Old 04-14-2013, 03:34 PM   #10
Vulkem seal is a heavy bodied sealer that never completely totally hardens.
It's used on larger mostly exterir seams, like the top of the windows, over the entrance door, around all the ceiling vents, on the frame, etc.
Therefore it lasts a long long time.
Airstream has been using it for over 40 years.
A parts stocking dealer would have it.
Old 04-14-2013, 03:35 PM   #11
eljay's Avatar
1968 24' Tradewind
Vulkem, now known as Trempro 635 can be purchased from Vintage Trailer Supply or your local Fastenal dealer. It is a high quality polyurethane sealant.
Eljay
Re-installation Rear Window Glass 1968 Overlander International Rhodo1937 Windows & Screens 17 07-17-2016 07:32 AM
Interior window trim 1969 calivw78 1965-1969 Sovereign 5 06-03-2011 12:31 PM
Cleaning the window trim easyride Cleaning, Stripping & Polishing 2 05-25-2011 10:16 PM
Replace missing front window with jalousie? Cruisette Windows & Screens 6 03-31-2011 04:23 PM
