Old 08-13-2012, 12:02 PM   #1
mukluk25's Avatar
1967 26' Overlander
Carbondale , Colorado
Window trim adhesive
Hi, I just had one of my trim pieces that attaches to the edge of the glass fall off. I see that inside the trim piece someone had put maybe 10 spots of some sort of adhesive then stuck it to the edge of the glass. What should I use to stick in back on? Parbond? Thanks
mukluk25 is offline   Reply With Quote
Old 08-13-2012, 12:20 PM   #2
RGates
Randy Gates's Avatar
1968 20' Globetrotter
Thousand Oaks , California
Use Sealant
I used Clear RTV silicone adhesive sealant. It is usually found in your automotive section at hardware stores everywhere. Fill the entire channel and insert over the glass. Trim off later with a razor blade the excess. Its good stuff. Good Luck.
Randy
Randy Gates is offline   Reply With Quote
