Old 10-11-2013, 09:12 AM   #1
69SlvrBelle's Avatar
1969 27' Overlander
Wrightsville Beach , North Carolina
Window Supports
Hey all, I am resending this question because I cannot find the original I sent out.
So, I am trying to remove the window support arms from the window brackets and the "stud/nipple?" is secured by a very small "lock ring". What is the easiest way to remove that rind so I can separate the support arm from the bracket so that I can clean them up and repaint and then reinstall?
Thanks for your patience with a newbie!
69SlvrBelle is offline   Reply With Quote
Old 10-11-2013, 09:19 AM   #2
Break it off and reistall using a nut, as Airstream did later on.
You will have to thread the end of the lift arm.
Or, use a split washer.
