Old 10-01-2016, 11:21 AM   #1
1972 25' Tradewind
Norval , Ontario
Window sliders lubrication.
Hi all.....I have a question about the plastic window sliders in my 1972 Tradewind. They are very stiff and I'd like to lubricate them. I'm wondering what would be the best lubricant to use for those plastic sliders.
White Grease?
WD 40?
thanx in advance for any advice.
BigDeeAirstr is offline   Reply With Quote
Old 10-01-2016, 11:57 AM   #2
Maniacal Engineer
barts's Avatar
Menlo Park , California
Anything that remains moist will attract dust & dirt, making the problem worse. Apply some silicone lubricant. Spray into a cup, and apply w/ Q-tip.
- Bart
Bart Smaalders
Menlo Park, CA
barts is offline   Reply With Quote
Old 10-01-2016, 04:16 PM   #3
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
There are some "dry" aerosol lubricants. Experiment. Silicone is fine, but doesn't always last.
As much as possible clean everything thoroughly first. If this means a toothbrush and a reduced diameter fitting for the vac cleaner,,so be it.
Hensley Arrow. 9-cpm solo, 15-cpm towing
Hensley hitch lubrication Brian Hobin Hitches, Couplers & Balls 11 02-11-2009 06:24 AM
Hitch Lubrication? AndyPenny Hitches, Couplers & Balls 13 11-21-2007 02:59 AM
Stabilizer lubrication? Fyrzowt Jacks, Stabilizers, Lifting and Leveling 14 09-16-2006 05:08 PM
Bal Stabilizer lubrication mandolindave Jacks, Stabilizers, Lifting and Leveling 4 02-19-2004 09:51 PM
Hitch ball lubrication Kistler Our Community 9 05-12-2003 12:48 PM
