Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Windows & Screens
Old 01-06-2016, 03:54 PM   #1
1977 23' Safari
Carberry , Manitoba
Window sealing for a 77 Safari
When I look at my window frames where they meet the exterior skin, in places there seems to be a slight gap or space between the riveted frame and the skin. It looks like there is some black material in this gap. In other spots along the same frame, the frame appears to sit flush against the exterior skin. Is there a gasket between the riveted window frame and the exterior skin or is the black I am seeing just a buildup of sealant and dirt? From what I have read on the forums I would think that I should be resealing those spaces and along the edges where they fit flush with a sealant like parbond? If it would clarify, I can take a picture of this and add it to this post tomorrow.
TIA Lorry
cp1977 is offline   Reply With Quote
Old 01-06-2016, 04:10 PM   #2
youngpeck's Avatar
1976 25' Caravanner
Salt Lake City , Utah
Pictures would be great! They always help.
youngpeck is offline   Reply With Quote
Old 01-06-2016, 04:52 PM   #3
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
There is a foam gasket between the window frame and the exterior skin. over time this gasket starts to fail. See my thread below for how I fixed this problem, it starts at post 427 my thread.
Old 01-06-2016, 06:24 PM   #4
1977 23' Safari
Carberry , Manitoba
Thanks Aero, when you reinstalled did you use any sealant between frame and exterior skin? Post 427 doesn't say. I'm not sure I want to pop all my windows out as I am pretty sure they are all similar. That might be next winter's plan. I haven't had any trouble with leakage since I have had the unit. I am in the early stages of polishing the exterior and recaulking where necessary. Lorry
Old 01-06-2016, 06:29 PM   #5
1977 23' Safari
Carberry , Manitoba
Never mind Aero, I just read further into that thread where you explain that you used aircraft fuel tank sealant in place of all that type of oem gasket... thanks again.
Footer - Window Sealing Advice Sought Tim Foote Windows & Screens 0 11-11-2013 06:34 AM
Window sealing questions? dkrukosky Windows & Screens 5 12-04-2012 08:09 AM
'72 Overlander window sealing...???? Sodbust Windows & Screens 5 05-17-2012 07:12 AM
Lower window sealing Brianv512 Windows & Screens 9 06-13-2011 06:04 PM
window and door sealing rubber gaunnyno Windows, Doors, Locks & Vents 1 06-30-2010 12:01 PM
