Old 01-22-2009, 09:23 AM   #1
1975 25' Tradewind
Central , California
Window sealant
Window leak, outer sealant? Airstream has found the stickiest substance known to to man. I am sealing a leaky window. As I was removing the gray outer sealant I found it was just covering a super sticky sealant under it.
I am going to clean the seam the best I can without removing the window and re seal it. I just need to know what to replace the sealant with and where I can get the right product.
Pepsi is offline   Reply With Quote
Old 01-22-2009, 01:16 PM   #2
Outer sealers are Par-Bond and Vulkem.
Glass to window frame sealant crispyboy Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 04-21-2007 10:33 AM
Window Sealant Sundance Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 04-21-2007 09:35 AM
Sealant Uses bsherman Leaks - Weatherstrips, Gaskets, Caulks & Sealants 11 12-09-2005 07:44 PM
Where to get sealant? blickcd Leaks - Weatherstrips, Gaskets, Caulks & Sealants 20 01-25-2005 03:57 AM
sealant Chuck Leaks - Weatherstrips, Gaskets, Caulks & Sealants 6 11-06-2002 08:41 AM
