11-16-2012, 04:43 AM
1975 27' Overlander
Landenberg
, Pennsylvania
window seal confusion
I need to replace all the seals on my 75 overlander but I am a little confused as to what to buy. is the D seal used for windows instead of the double flair type of seal? are the access hatches a different seal or do they also use the D seal as a replacement? finally what about the Door what seal do I use for that?
11-16-2012, 04:52 AM
Retired.
, At Large
The windows use the double seal from the factory. You can use the narrow D seal as a replacement if you want to.
Compartments and main door use D seal, wider than the one for the windows.
11-16-2012, 07:10 AM
Corona
The small "D" gasket for the windows are a far better gasket.
Your access doors and entrance door uses the triangular shaped larger gasket.
11-16-2012, 07:43 AM
2019 27' Flying Cloud
Albuquerque
, New Mexico
In my experience, Airstream used both "D" gaskets and double-lip gaskets in 1975.
They used "D" gaskets on the side windows (with radius corners).
And double-lip gaskets on the front and rear windows (with square corners).
When I installed new seals on my two 1976 Airstreams, I used the same approach with good results.
Hope this helps.
Ken L 2019 Flying Cloud 27FB
2020 GMC Sierra 1500 Crew Cab 6.2L Max Tow Four Corners Unit WBCCI #5783
11-16-2012, 08:28 AM
1975 27' Overlander
Landenberg
, Pennsylvania
11-16-2012, 08:45 AM
Albuquerque
, New Mexico
Doesn't Look right
Neither seal looks right for your application.
Please contact Inland Andy by PM and get it right the first time.
In both cases (door and windows), your Airstream came with more substantial gaskets than what you posted.
Nice Airstream, by the way!
11-16-2012, 10:32 AM
Retired.
, At Large
Those are what you would use on your trailer, unless you want to use the double edge seal for the windows.
12-16-2012, 06:04 AM
1975 27' Overlander
Landenberg
, Pennsylvania
what direction dose the Door seal go on? dose the fatter part go in against the door lip or out toward the outside edge?
12-16-2012, 08:30 AM
Corona
The square part of the gasket goes into the square part of the door frame.
That leaves a 45 degree gasket that closes on the door jamb.
12-22-2012, 01:49 PM
1975 27' Overlander
Landenberg
, Pennsylvania
ok got the door all bolted back on with the new seal in place. The trouble is, it does not seem to seal tight at the top of the door? Almost like the door has lost some of its curvature to match the curve of the door frame.
12-22-2012, 02:06 PM
Corona
The entrance door should be 'flush" with the door jamb.
If not, then the door has been damaged and bent out of shape.
Also, check the door extrusion at the lock to see if that area is cracked.
