Old 10-25-2006, 12:42 PM   #1
1987 34.5' Airstream 345
Corvallis , Oregon
window screens for 345 motorhome removal & replacement
Anybody know how to remove and replace the screens? I just had my windows tinted and removing the screens wasn't easy. I don't want to mess them up putting them back in.
Also, anyone know where I could find replacements for the ones I bent taking taking them out?
How would someone clean the windows if these screens can't be removed?
The curved windows in the rear weren't easy to tint either, but the guy I found did a fantastic job. Anybody in the area (Portland OR) should call Jeff to get their windows tinted. His number is 503-209-9146.
Peter E.
NW TINMAN is offline   Reply With Quote
Old 10-26-2010, 09:47 PM   #2
Silver Goose
1990 25' Airstream 250
Kingston , Ontario
hi Peter, I have a 250 motorhome and want to replace the screen material on the frames but can't figure out haw to get at the whole screen to do so. Did you find out any way to remove the screens from the window frame? Or do you know of any way to replace the screens while the screen frames are still in the window frame?
Claude
250 bus is offline   Reply With Quote
Old 10-28-2010, 07:58 PM   #3
Athens GA
Myrtle lynn's Avatar
1995 28' Excella
1989 34' Excella
1986 31' Sovereign
Athens , Georgia
There are little Phillip screws that you can see from outside the coach. I am having my windows tinted and that's what I figured out. Hope this helps.
Athens GA
Myrtle lynn is offline   Reply With Quote
Old 10-28-2010, 08:40 PM   #4
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Those screen are a royal pain: I removed ours and only put them back in when we're in bug country, which is not that often. That way you can keep the windows and channels clean. I marked all of ours as to location, they are all different +- size on our coach. Developing a "warping" technique to get them in and out is a learned art.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Oval Window Frame Replacement MikeMikeMI Windows & Screens 8 12-30-2007 10:49 AM
Window Removal Rob Windows & Screens 2 08-31-2002 07:49 PM
Window Frame Replacement Charles D. Bennett Windows & Screens 20 08-16-2002 06:03 PM
Acrylite Window Replacement Gordon Watt Windows & Screens 12 08-12-2002 08:46 AM
Window Frame Removal 64GT Windows & Screens 4 04-09-2002 12:40 PM
