Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Windows & Screens
Old 01-18-2004, 02:22 PM   #1
smallfry
Profile:
Window screen replacement
Every book on repairs makes screen replacement seem simple - and it would be if the dang frame came out and could be laid out flat on a table. My Bubble however has the frame attached to a large aluminum trailer. Oh, not "large" large but the frame is extremely tough to get to with any normal window screening tools. I've make a little tool out of small diameter steel rod but it's not working too well - I can't get any leverage on it. Any suggestions?
Jo Ann
smallfry is offline   Reply With Quote
Old 01-18-2004, 06:59 PM   #2
Dbraw
Profile:
Screen work
Most home improvement stores sell a tool for replacing the screens. It looks kinda like a pizza cutter with a wheel on each end. One is which has a convex wheel is for starting the spline and the other is for final insertion of the spline. When replacing the screen, start with a few inches more screen than is required on all sides, and final trim after the spline is inserted. Use a sharp knife like an Xacto with a new blade to do the trimming.
Dan
Dbraw is offline   Reply With Quote
Old 01-18-2004, 07:12 PM   #3
j54mark
Profile:
As I read the original post, Jo An has the tool, she just cannot use it with the screen installed in the window frame. I think her question is more along the lines of how to remove the screen frame so she can work on it.
Mark
Old 01-19-2004, 11:00 AM   #4
Ken J
Profile:  1958 26' Overlander
Tijeras , New Mexico
Jo Ann
Look at www.vintageairstreams.com - RJ has a series of photos showing how he rebuilt his windows.
Ken J.
Ken J is offline   Reply With Quote
Old 01-19-2004, 11:01 AM   #5
wahoonc
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
Ken,
You have an extra "s" in there www.vintageairstream.com Should do the trick
Aaron
Old 01-19-2004, 11:10 AM   #6
Ken J
woops - Thanks
Ken J.
Old 04-12-2004, 10:58 AM   #7
tin can luv
tin can luv's Avatar
Profile:  1968 22' Safari
1976 27' Overlander
Newport , Washington
Images: 82
Is there special screen for airstreams????
Stealing this thread for my questions....I need to replace the screens,a nd I don't see anything that looks like the airstream screen color at home depot, any suggestions??? where can I get new????
Ron
Ron ... now in Newport, Washington
[font=Impact][font=Arial Black]
tin can luv is offline   Reply With Quote
Old 04-12-2004, 11:28 AM   #8
62 Overlander
62 Overlander's Avatar
Profile:  2005 25' International CCD
1954 25' Cruiser
Paradise , Texas
I used the solar screen they sell at Home Depot. I bought the charcoal color thinking it would give the windows a tinted look, which it did. It also blocks a lot of heat, the downside is that the weave is so tight that natural breezes don't blow through as easy a screen with the bigger weave.
I also lightly sanded the frames and painted them with Aluminum spray paint before I put the screen in and they looked new again.
Paul.
Paul & Annie
"No matter where you go, there you are..."
WBCCI #7162
Charter Member - Heart of Texas Camping Unit
AIR #1565
62 Overlander is offline   Reply With Quote
Old 04-12-2004, 12:33 PM   #9
jaco
jaco's Avatar
Profile:
Green Window screen ???
My 74 has a green fabric (nylon or fiberglass I guess) screen. I have not seen this in my many trips to Hdw or Bldg Supply houses. Anyone know what color and style was original in the 70's?
Not that I am trying to stay authentic, I couldn't care less about the color as long as they all match in front room and galley. The green however looks nice
jaco is offline   Reply With Quote
Old 04-12-2004, 02:08 PM   #10
Tripp
Profile:
Images: 55
jaco,
Interesting screen color! I just replaced my screens on the 73. I went with charcoal fiberglass. The stuff I replaced I believe was original and was a grey color, also fiberglass. My 56 has aluminum screen. The 77 has grey fiberglass.
I'd just go with what you like.
Tripp
Tripp is offline   Reply With Quote
Old 04-12-2004, 08:27 PM   #11
davidz71
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
I just replaced 3 screens with grey fiberglass I bought from Lowe's Home Improvement. They matched what was in the door and windows perfectly.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 04-12-2004, 09:59 PM   #12
Cedars
Cedars's Avatar
Profile:  1983 31' Excella
Waterloo , Iowa
If color is important to you and money no object, consider copper screen. You could then treat the copper with a solution to make a green patina on it. On the other hand, isn't there some mysterious reaction between aluminium and copper that is corrosive?.......
Oh well, it's the thought that counts.
Elizabeth in Iowa
The carpeting is gone! The carpeting is gone! Long live the cork floor!
Cedars is offline   Reply With Quote
Old 04-12-2004, 10:04 PM   #13
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
You may have to do a bit of hunting, but there is a grey fiberglass screen that is still made. I like the fact that the screen allows in some of the light. I redid a coach with the dark stuff and did not like it as well.
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Old 04-12-2004, 10:08 PM   #14
Tarheel
Tarheel's Avatar
Profile:  2001 34' Limited S/O
Moyock , North Carolina
Images: 21
On my 74 I unscrewed the screen frame, removed the old screen, reinstalled the new fiberglass screen and spray painted the entire frame and screen an off white. I took my time and did not get a lot of build-up on the screen itself. I had to paint the screen from both sides but it look like what I took out. I don't see why green paint would work any differently.
Keep the shiny side up.
WBCCI # 3485
Region 3 1stVP
Past President Tidewater Unit 111
visit tidewater Virginia's web page @
www.tidewaterwbcci.com
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
