Old 03-10-2009, 03:03 PM   #1
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
window sash, how is...
Heres a picture of the old window sash and how it is attached...we have the new window...but we can't get anything to budge...any ideas for the 70 model?
ID:	76717   Click image for larger version
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 03-10-2009, 03:24 PM   #2
You must snap the round ring that holds the lift arm to the window.
Once that ring is off, you can lift the window over your head, and the window will drop out.
All that is holding you back is that ring.
Old 03-10-2009, 03:28 PM   #3
1970 27' Overlander
you mean the more silver one under the tiny cap...does the cap come off or un screw? and you mean snap as it is a solid circle go ahead and break it?
Old 03-10-2009, 04:09 PM   #4
1970 27' Overlander
ok we got it off...we had to rip out the larger flatter ring beneath the smaller round ring to get to it THEN -snap the small one out and off with a medium sized flathead screw driver...that was tricky and this has been a mystery to me for at least seven months...but the window is in now and thanks again. P.S. If I ever die, I bet this is going to be one of those moments that flashes in front of me Ha Ha!
Window Latch Assembly (window locks) Sue&Von Windows & Screens 17 02-10-2009 07:32 PM
Replacing Nylon Window Guides - not holding window up Tom Bray Windows & Screens 5 06-16-2008 07:52 AM
need help on double j sash? supergrafix Windows & Screens 0 06-06-2008 11:29 PM
Need Window E. C. Rogers Windows & Screens 1 09-13-2007 11:26 AM
replacing rear window/sash Rick's73 Windows & Screens 2 07-28-2003 08:20 PM
