Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Windows & Screens
Old 10-06-2010, 12:37 PM   #1
1978 28' Ambassador
Savannah , Georgia
Window rivets broke...help!
Removing side window. Had it at a 90 degree angle waiting for it to release. It did not release so raised it a little higher. Must have gone way beyond the 90 degrees and the ten rivets that hold the piece that slides into the holder broke. Now have a floppy piece of trim. These rivets do not look like pop rivets. What do I do now? Is there someplace I can go to get them replaced here in Savannah. Would guess they are bucked rivets. Do not want to leave the AS exposed to the "have nots" who "take all". May have to spend the night in the AS. Help! Thanks. Jack
Skamper1 is offline   Reply With Quote
Old 10-06-2010, 01:27 PM   #2
kennethowens's Avatar
1975 Argosy 24
Malakoff , Texas
You can use 5/16 to 1/2" length 1/8th" standard rivets in a pinch.
Sold at the local hdwr store...a thin layer of caulk in the hole
and atop the rivet head is good.
kennethowens is offline   Reply With Quote
Old 10-08-2010, 05:49 AM   #3
1978 28' Ambassador
Savannah , Georgia
Thanks for all the quick help. Ended up using 1/8" short pop rivets. Upon closer inspection I see where there was a problem with this window and it had been "fixed" before. Straightened the hinge edge and reriveted with sealer. Shiney and new gasket. Most of the time was spent removing old gasket and years of corrosion. Did learn to clean out hinge track before removing next window. Thanks. Jack
Help broke a window ! marksamuel Windows & Screens 5 06-05-2010 01:52 PM
I just broke a window-help?? Woodin Windows & Screens 2 09-19-2008 01:49 PM
Window crank broke Devoman Windows & Screens 4 12-16-2007 01:10 PM
Broke my window! Stefrobrts Windows & Screens 31 08-05-2007 06:35 PM
window broke, need advise on how to fix infinite LUX Our Community 4 08-03-2003 08:55 PM
