Old 01-21-2006, 11:07 AM   #1
Tin Can's Avatar
2005 31' Classic
wilson , New York
Images: 8
Window replacement
Greetings all, as some of you might have read I have a porthole window that needs replacement. It will be done under warranty by the dealer. My question is how is it replaced. Is it from the inside or the outside? Thanks for any input.
Tin Can
"Your edumacation ain't no hipper than what you understand"- Dr. John
'05 Dodge 2500 SLT 4X4
TAC# NY-5256
Tin Can is offline   Reply With Quote
Old 01-21-2006, 12:33 PM   #2
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Tin Can
Both, but the bulk of the work occurs from outside unless they use bucked rivets in which case it would be 50/50 When I replaced my Vista View I used Olympic Rivets and most of the work was done from the outside.
Aaron
WBCCI #XXXX AIR #2495
Old 01-21-2006, 06:35 PM   #3
Tin Can's Avatar
2005 31' Classic
wilson , New York
Images: 8
Wahoonc, thanks for the info. Tin Can
TAC# NY-5256
Old 04-05-2006, 03:00 PM   #4
enduroryda's Avatar
1994 21' Sovereign
Down on the corner... , CT
Yaaa! Just got my replacement window in from Colaw's Salvage...Can anyone give me a heads up how to release the pivoting hinge on the top from the window frame...this is on a 94' Sovereign side window.. I am just replacing the glass and top hinge part. It looks like it's just sitting in there but I'm not sure how much pressure I need to put on it to pull it out I guess....Thanks in advance! Ann
enduroryda is offline   Reply With Quote
Old 04-05-2006, 03:48 PM   #5
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
Ann,
you release the hold open stuff by removing the screws/bolts, then lift the window up past 90 degrees and it will release. Putting back in is a bit more involved, you have to get it started then push down on the center as you swing it down.
Aaron
Old 04-05-2006, 04:02 PM   #6
enduroryda's Avatar
1994 21' Sovereign
Hey Aaron...Thanks....
I got to the point of bolt removal..it's just pivoting and I have had it all the way up like you said..as that's what I thought I read somewhere previously..just doesn't want to seem to drop out..should I try to gently pry the pivot point at the beginning??
Old 04-05-2006, 04:19 PM   #7
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
I think you need to just press down GENTLY at the center of the window. Mine popped out when I rotated thru the 90 degree range.
Aaron
Old 04-05-2006, 08:18 PM   #8
enduroryda's Avatar
1994 21' Sovereign
Yes!!! I got it!
Had to actually open window till it was about at 10:30...sprayed down the seam with WD and it started to lift in the corner...worked at it with a screwdriver with the tip covered w/ masking tape and VIOLA...it dropped out
Now the fun begins tomorrow of trying to get it in!! This should be interesting.
Thanks for you help Aaron!!
Old 04-07-2006, 03:03 PM   #9
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
Yes!!! I got it!
I'll make sure to cover my ears
Aaron
Old 04-07-2006, 04:27 PM   #10
enduroryda's Avatar
1994 21' Sovereign
Aaron
Not a one cuss word was said.....Went in like a breeze
Now the night before...that's another story
It's all in the angle isn't it
Old 04-09-2006, 10:15 AM   #11
I have to replace the glass in a pivoting oval window in a '71 excella.
What is the secret technique for removing (& reinstalling) the window & frame so I can replace the glass?
It seems that all access doors and pivoting windows have this same wierd hinge which looks like an aluminum lockseam. Ive tried opening some of the
access doors and only succeed in damaging this "lockseam"
one of the access doors poppped off and I cannot get this "strange" lockseam hinge back together.
Any tips would be appreciated.
Starker White
Strongmachinery@gmail.com
815-986-8178
strongmac is offline   Reply With Quote
Oval Window Frame Replacement MikeMikeMI Windows & Screens 8 12-30-2007 10:49 AM
Curved side window replacement michel88 Windows & Screens 7 09-29-2006 09:20 AM
Window Replacement Jim Sease Windows & Screens 1 12-29-2002 07:05 AM
Window Frame Replacement Charles D. Bennett Windows & Screens 20 08-16-2002 06:03 PM
Acrylite Window Replacement Gordon Watt Windows & Screens 12 08-12-2002 08:46 AM
