Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Windows & Screens
Old 04-09-2008, 07:06 AM   #1
ronsgto
Profile:  1974 27' Overlander
Placerville , California
Window replacement 1974 Overlander
Hey any help would be greatly apprecited. Have a broken window on my Airstream. Its the window just to the right of the door. Small oval window I believe just below the main window that opens. Anyone know where to get such a window?
ronsgto is offline   Reply With Quote
Old 04-09-2008, 07:45 AM   #2
The Flintstones
The Flintstones's Avatar
Profile:  1970 27' Overlander
Houston , Texas
Hi and Welcome
I would drill out old rivets and replace with lexan or take frame to local glass shop and have them cut a piece to match. Be sure and drill out rivets as explained on this site or new rivets will not fit properly and seal new rivets and window with vulkem.
good luck
James
____________
1970 Overlander
The Flintstones is offline   Reply With Quote
Old 04-09-2008, 07:55 PM   #3
ronsgto
Thanks kind of new to this forumn guess I can do a search on rivets and find the thread your talking about.
Old 04-10-2008, 07:46 AM   #4
The Flintstones
Houston , Texas
From Andy at Inland RV
Hi,
Here are the instructions per Andy, I don't know how to link his thread so I just copied it:
"The three drill bit sizes that you will need are #30, 21 and 11.
We have a drill bit assortment kit available.
Olympic rivets are used on the exterior, unless you have a portion of the interior off. You then could use "buck" rivets.
The underbelly uses 3/16" pop rivets.
Drilling out the original buck rivets takes a # 30 drill bit. The holes are then opened up with a # 21 drill bit for the olympic rivets. "DO NOT" drill out the od original rivets with a # 21. The idea is that you can and will have oval holes with the #30 drill bit, since you cannot absolutely center the drill bit. Those holes are trued back to round with the second drilling, using a #21. If you attempt to drill out the old rivets with a #21, again you will have oval holes. The problem then is that you would have to true the hole with a #11and the use an oversize 3/16 rivet. Olympics are not available in 3/16, and if they were, the rivet head would be much larger than the buck rivet heads.
Also you will need a "shaver" if your going to do a bunch of rivets. If not, then you can dress then down with a Dremel tool, but they will all have a different appearance from each other.
You should use "vulkem" sealer when replacing rivets and/or sheet metal."
____________
1970 Overlander
Old 05-01-2008, 06:57 AM   #5
ronsgto
A little confusion
I am still a bit confused on the rivets. I was reading another post and it looks like the olympic rivets are 5/32". I want to make sure I am buying the right thing. I have drilled out the rivets per instructions but have to clean the surface and do a final drill through the holes. Where is it suggested to buy the rivets. Looks like Vintage or Inldand RV just want to make sure of the size for the window.
Old 05-01-2008, 10:15 AM   #6
Distantdrummer
Distantdrummer's Avatar
Profile:
I thought that window had a retention ring that allowed glass removal from inside without rivet removal.
I know some of the similar shaped Vista-View windows have the removal ring.
Do you not have a 1974 service manual?
Distantdrummer is offline   Reply With Quote
Old 05-02-2008, 07:56 AM   #7
ronsgto
Not on this one. Its a double window and the rivets have to be drilled out. I have allready done that just not sure of the excat size olympic rivet to purchase.
Old 05-02-2008, 08:07 AM   #8
bedfords
bedfords's Avatar
Profile:  1972 27' Overlander
1975 29' Ambassador
Littleton , Colorado
How broken?
So its a double pain window. Are both pains broken? I have a sigle pain. You might could use the glass to replace yours?
Master of the Tin-Can
and thats not saying much
bedfords is offline   Reply With Quote
Old 05-03-2008, 08:59 AM   #9
ronsgto
Ya double and both broken thanks anyway. Still looking for info on the right size olympic rivet to buy.
Old 05-04-2008, 08:11 AM   #10
The Flintstones
Houston , Texas
Call Inland RV they have and know what size.
James
____________
1970 Overlander
Old 07-18-2008, 09:01 AM   #11
ronsgto
Sorry for the dealy in posting I call Inland and they have the right stuff. Shiping standard mail $12.00 ouch.
71 Overlander window spotszilla Windows & Screens 15 10-10-2007 09:18 PM
1974 excella front window docu post john hd 1973-1974 Excella 500 22 08-06-2004 01:53 PM
1974 Overlander somefun Airstream Trailer Forums 3 05-16-2003 01:45 PM
PROUD NEW OWNERS of a 1974 International Overlander Anna Our Community 6 11-09-2002 07:29 PM
1974 Argosy- need front window dootsie Windows & Screens 1 10-21-2002 08:57 AM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
U2 Forums
