Old 07-10-2005, 08:58 AM   #1
1970 25' Caravanner
Pasco , Washington
Window Replacement
Any ideas on were to get replacement windows for the airstream trailers? We have a 1970 that the former owners replaced the front window with plex-glass. We would like to change this out.Thanks
Liz
Pasco WA
bubba99301 is offline   Reply With Quote
Old 07-10-2005, 09:13 AM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Window Replacement
Greetings Liz!
Liz
Pasco WA
If the window you need is the center window, there are two good possibilities. If it has flat glass, an automotive glass center should be able to cut and install replacement glass; or the replacement window may be available from an Airstream dealer or Service Center.
If the window that you need is one of the wing windows (the small windows on either side of the front center window), about the only source for replacement is via either an Airstream Dealer or Service Center.
A third possibility for either window would be from a salvage dealer. One who often has 1970s salavage units is Colaws located in Carthage, MO -- there are others who may be closer to you.
Good luck with your search!
Kevin
Kevin D. Allen
AIR #827
Old 07-10-2005, 11:21 AM   #3
desi arnaz's Avatar
anyone know where i can get a c/s curved and a fron flat with frame for a 2000 excella? i have tried everyone and cant find them. i can get them from airstream but they are about $700 each.
desi arnaz is offline   Reply With Quote
Old 07-10-2005, 03:26 PM   #4
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Retrofit Vista View Windows
I'm getting ready to retrofit Vista View Windows in my 73 Sovereign. The front 2 windows (the one in front of the door curbside and the one roadside opposite) look pretty straightforward. There are 2 areas I could use advice on:
1. The salvage windows I acquired had some sort of gasket in addition to caulking. I need advice on where to get gasket material and/or making a permanent window seal.
2. There is a rivit line that extends from the middle of the second large window roadside over the roof. This suggests to me a frame rib is under it. If so, I don't think I should try to cut out a section of rib for the window and am willing to settle for just the two front Vista view windows instead of the 2 roadside and 1 curbsiide. Has anyone any experience with this?
Old 06-07-2010, 08:47 PM   #5
2007 19' Bambi
Antelope , California
Images: 12
2007 Bambi SE window replacement
Anyone know where to get a replacement window for our Bambi SE?
Sactown is offline   Reply With Quote
Old 11-17-2011, 09:52 AM   #6
Dawson , Georgia
Window replacement
Hey everyone.
I just bought my first Airstream, a 70 or 71 Tradewind 25. One of the small windows opposite the door is missing and the previous owner screwed a piece of aluminum over the hole. Does anyone know where I can get a replacement window. THe frame appears to be intact. Is it possible to replace the glass?
paulrakel is offline   Reply With Quote
Old 11-17-2011, 10:26 AM   #7
1997 25' Safari
1973 25' Tradewind
Greenville , South Carolina
Hi,
I am in Greenville, SC and might can help you. Can you measure the window area L x W. Also take a picture of the framed area of the window you need. I have both a 69 Globetrotter and a 73 TradeWind. They share a lot of the same windows for those years.
Email me direct at r_whiten@hotmail.com
Rick
montanablue is offline   Reply With Quote
Old 11-17-2011, 10:27 AM   #8
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
I replaced the two plexiglass side windows and the broken front window on our 65 caravel. All those windows are 1/8" thick. I had new glass cut at a glass shop. I got new adhesive on a roll and new seal on a roll from Vintage Trailer Supply.
Window Gasket
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
https://www.youtube.com/watch?v=Bp3nuNtlZcA&t=331s
https://www.youtube.com/my_videos?feature=mhee
Old 03-21-2012, 04:16 PM   #9
1969 27' Overlander
Stockton , California
We have a 69 Overlander. We were driving and the small curved left window and the flat big window in the middle just shattered. We are traveling now and wonder how hard it is to replace the big window. The small one I am replacing with Plex glass until we get home. Don't know why this happened! Any advice would be appreciated.
silvercabin2 is offline   Reply With Quote
Old 03-21-2012, 05:32 PM   #10
Both those windows are available.
Be sure you contact your insurance company since those windows are not cheap.
Also DO NOT destroy the large front window frame.
It will be necessary to remove the hinge from it and install it on a new window.
Or you can make arrangements with a parts stocking dealer to change that hinge for you.
Warning. If you attempt to install a new window that does not have the correct hinge, you will snap off all the rivets.
Airstream, unfortunately used a goofy hinge for the 69 windows.
Oval Window Frame Replacement MikeMikeMI Windows & Screens 8 12-30-2007 10:49 AM
Curved side window replacement michel88 Windows & Screens 7 09-29-2006 09:20 AM
Window Replacement Jim Sease Windows & Screens 1 12-29-2002 07:05 AM
Window Frame Replacement Charles D. Bennett Windows & Screens 20 08-16-2002 06:03 PM
Acrylite Window Replacement Gordon Watt Windows & Screens 12 08-12-2002 08:46 AM
