Old 12-25-2011, 01:38 PM   #1
2012 27' FB International
Boulder , Colorado
Window repair/adjustment?
2012 27FB International. Side window would not stay in the first (smallest) open position, which upon inspection is due to loose rivets on the bottom of the black plastic three position arm support on one side. Upon further inspection it appears that the aluminum "J" hinge at the top has more 'slop' in it than on the other windows. Can the "J" hinge be adjusted? What rivets do I need to re-rivet the arm supports? Any ideas as to why this happened? Unusual or common problem? We are living in it for the winter, so leaving it at a dealer is not a great option right now even though it is brand new and under warranty. Any help/advice will be very much appreciated.
motozen is offline   Reply With Quote
Old 12-25-2011, 01:43 PM   #2
You can use 1/8 pop rivets for the window position guides.
The rivet length should be 3/8 or 1/2 inch.
The window hinges are "NOT" adjustable.
They all have some "slop".
Old 12-25-2011, 01:46 PM   #3
1981 31' Excella II
New Market , Alabama
I would get some silver duct tape and seal the window with that till you can get it fixed.
Perry
Old 12-25-2011, 01:56 PM   #4
Boulder , Colorado
Perry
The window is perfectly operational, stays open on the two upper slots, and closes just fine. I just need to re-rivet the support and know whether I can adjust the upper "J" hinge. Perhaps I wasn't clear on that, but thanks anyway.
Old 12-25-2011, 06:35 PM   #5
Boulder , Colorado
Thanks, that's the info that I needed. Since two of the rivets are loose, but still attached, any idea what size drill bit to use to get the loose ones out (I assume 1/8")?
Old 12-25-2011, 07:35 PM   #6
A # 30 drill bit is recommended for all 1/8 inch pop rivets.
A 1/8 drill bit, will not allow enough clearance for a new rivet, since the hole will not be exactly round.
Old 12-26-2011, 10:05 AM   #7
Boulder , Colorado
Thanks Andy!
'58 Hehr Window - Is this the correct window operator replacement? mello mike Windows & Screens 22 10-08-2012 09:49 AM
AS280 - Front (driver) sliding window latch dalefox Classic Motorhomes 13 01-05-2012 07:41 PM
Broken Window Repair Firstlight Windows & Screens 10 10-20-2011 09:45 AM
Rear window leak fixed! Really? I think so. 1964 GlobeTrottin 1960 - 1964 Globetrotter 0 04-30-2011 06:42 AM
Replace missing front window with jalousie? Cruisette Windows & Screens 6 03-31-2011 05:23 PM
