Old 10-08-2006, 08:26 PM   #15
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
How Exactly Did You Get Them Off
Spent the better part of the afternoon trying to get these off a 71 Overlander window. Tried all the spreading tools that you tried without success. Someone told me to just get the edge of a wire cutter under them and break them - I can't even do that. What did you do with the Dremmel that worked.
What size snap ring did you use as a replacement - 1/4..?
Thanks much....
Old 10-08-2006, 09:40 PM   #16
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
I used the thin cutoff wheel and basically scribed the side of the original snap ring enought to weaken it. Then I used a small flat blade jewlers type of screwdriver to pry it out. With the weakened cut in place the ring would break in peices.
I think the replacement was 1/4"
Good luck with your window work!
-Tim
theVAP - Airstream Podcast
Old 10-09-2006, 08:37 AM   #17
The Flintstones's Avatar
1970 27' Overlander
Houston , Texas
Used the thin cutting blade wheel for the dremmel tool as tim described, cut until you get through one side of the snap ring, then push with small screwdriver until you get a gap on the other side, then pop off. I just did all but two windows all yesterday as I ran out of gasket material. Also used a chissle to scrap out old gasket and then a wire wheel and drill to remove all old gasket and glue. Super easy this way. Thanks also to Tim for his help.
next is the bathroom. Yee Haw!
James
The Flintstones is offline   Reply With Quote
Old 10-09-2006, 08:39 AM   #18
1970 27' Overlander
Houston , Texas
replacement clip
I used 3/16 C clips to replace mine.
James
Old 10-09-2006, 10:06 AM   #19
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
James
Thanks James,
I couldn't remember the size. I know I had problems with mine falling out until I got the right ones!
-Tim
1974 Excella front window docu post john hd 1973-1974 Excella 500 22 08-06-2004 01:53 PM
Window Removal Rob Windows & Screens 2 08-31-2002 07:49 PM
Try this!! Window frame oxidation removal trick... niftypkg Cleaning, Stripping & Polishing 2 08-23-2002 05:49 AM
Front Wing Window Repair Charles D. Bennett Windows & Screens 0 08-10-2002 06:04 PM
Window Frame Removal 64GT Windows & Screens 4 04-09-2002 12:40 PM
