Old 03-08-2009, 12:43 AM   #1
walter1's Avatar
1964 22' Safari
Foresthill , California
window removal 1964
How do you remove and reinstall the window glass from a 1964 Airstream?
Not the entire window frame from the trailer body.
Just want to disconnect the opener arm and remove the actual window glass frame at the hinge point across the top in order to install new glass/tinting.
Is it as simple as unlatch and crank open window, disconnect lifting arms, raise widow full open and slide hinge apart? Am I looking at drilling rivets just to replace window glass, or are there tricks to disassembly / reassembly?
walter1 is offline   Reply With Quote
Old 03-08-2009, 04:51 AM   #2
Originally Posted by walter1 View Post
It's as simple as unlatching, crank open the window, disconnect lift arms, raise window open, and slide apart.
Correct.
But there is one screw in the hinge that you must also remove.
Old 03-08-2009, 09:38 PM   #3
walter1's Avatar
1964 22' Safari
Thanks Andy, I was hoping it was relatively easy. I've fallen for that hidden rivet/screw before while taking things apart.
Old 03-12-2009, 09:32 AM   #4
flyrc's Avatar
1962 22' Flying Cloud
Yakima , Washington
64 window glass holding frame
Andy, you have surprised me in the past with the parts you have. I'm looking for the glass holding frame for the side window on my 64 Globetrotter. Either side will do since all the windows are the same I think windows from 61-65 are the have the same frame, am I right? I'm willing to modify the sheet metal on the curb side and move that window if I have to.
Thanks Wally
flyrc is offline   Reply With Quote
window tint removal bimpy Windows & Screens 8 02-21-2018 04:53 PM
Window Removal The Flintstones Windows & Screens 18 10-09-2006 10:06 AM
1964 Bambi II rear window firefly007 Windows & Screens 1 07-11-2006 03:49 PM
tradewind window 1964 frazer45 Windows & Screens 2 01-18-2005 10:45 AM
Window Removal Rob Windows & Screens 2 08-31-2002 07:49 PM
