Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Windows & Screens
Old 08-31-2002, 01:21 AM   #1
Rob
Profile:
Window Removal
I recently purchased a 72' Land Yacht. The more I dig in the more I find I need to replace. Such as window and door gaskets. Was wondering if there is an easy way to remove the windows without causing damage.
It sure would be nice to sit in a chair and apply the adhesive and new rubber gaskets.
Rob is offline   Reply With Quote
Old 08-31-2002, 09:07 AM   #2
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
I belive that the windows can be removed quite easily. First remove the knob on the end of the arms that raise and lower the window. Remove the screen. With the windows open you should be able to get to the window to "flip out" by lifting it past horizontial. Do this with care as it will fall out of the top track and you could drop it if you are not prepared.
The windows are hinged with an interlocking c shaped channel. By lifting it way up you are just unlocking the two c channels.
Installation is the reverse.
Prior to re-gasketing my entry door I used a dremel tool with a flapper wheel to get to clean aluminum for good adhesion. Saved hours of work removing old glue and weatherstripping that would just not come off. To remove the gaskets I reccomend a wide thin puttty knife.
Good luck
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Old 08-31-2002, 08:49 PM   #3
Rob
Profile:
Thanks I'll try that.
I have an airgrinder and steel brush/wheel. I'll try that for removing the old glue and chunks of dried up gasket.
I am so motivated to get this thing into shape. I just don't have time to go to my 9-5 job. Oh well, got to be able to pay for all the parts and materials.
Repost to part Forum (window part, 67 A/S) JimC Parts Archive 15 09-28-2003 10:45 AM
Report of window replacement in 1977 Minuet 6.0 kenny2 All Argosy Trailers 2 08-27-2003 08:11 AM
Try this!! Window frame oxidation removal trick... niftypkg Cleaning, Stripping & Polishing 2 08-23-2002 06:49 AM
Front Wing Window Repair Charles D. Bennett Windows & Screens 0 08-10-2002 07:04 PM
Window Frame Removal 64GT Windows & Screens 4 04-09-2002 01:40 PM
