Old 08-14-2010, 08:10 AM   #1
mwells4654's Avatar
1971 27' Overlander
Antlers , Oklahoma
Window Problems
On my 71 Overlander I have a few window issues. On the weatherstripping issue. I have shrinkage - how do I fix this. Also where can I get the trim piece in the photo. The PO broke one and I need a new one. On the front wing window there is no weatherstripping at all. Do I just use vulcam to repair or do I need something else. Thanks for you input. I know this has nothing to do with windows but do you know where I can get the wheel well trim?
ID:	108725   Click image for larger version
ID:	108727   Click image for larger version
Mel
2006 GMC 1500 SLE Crew Cab
5.3L V8 Towing Package
Equal-i-zer E2
AIR # 40365
TAC # OK-3
mwells4654 is offline   Reply With Quote
Old 08-14-2010, 09:23 AM   #2
Use vulkem to repair those windows.
To remove wing windows, take them apart, replace the gasket (that's not available), reassemble the wing windows and reinstall them with rivets,is a task that you don't even want to think about.
You can inject some vulkem into the window frame, push the gasket back into place, and tape the gasket so it cannot move allowing the vulkem to cure out, is a good way to go. After you remove the tape, you can add another bead of vulkem over the gaskets, forever sealing them in place.
Old 08-14-2010, 10:19 AM   #3
mwells4654's Avatar
1971 27' Overlander
Antlers , Oklahoma
Thanks for the info. Will work on that next weekend - if not sooner.
Mel
Equal-i-zer E2
AIR # 40365
TAC # OK-3
JC With Problems, Same Problems Goin Home ncbambi 2008 Safari SE 3 06-23-2009 09:44 PM
Update on Problems Problems pjude General Motorhome Topics 4 09-04-2007 06:02 AM
Window problems Rosemary66 Member Introductions 10 05-02-2006 10:42 AM
1976 Airstream with window problems manning Member Introductions 1 04-29-2006 09:32 PM
window problems jwaldin Windows & Screens 2 01-15-2003 09:56 AM
