Old 04-04-2012, 04:48 PM   #1
2006 28' Classic
Ancaster , Ontario
Window problem on a 2001 Safari
We own a 2001 Safari and we have 3 windows that are giving us a problem in that they will no longer fully open. It looks like it would be a fairly easy job to replace the centre mount window regulators. I call Our local Airstream dealer, they called the factory and the answer that I was given was "that company that made the window is not longer is business". They do have complete windows for 4 or 5 hundred dollars, but I was hoping for a little less expensive solution, any ideas?
Happy-rver is offline   Reply With Quote
Old 04-04-2012, 06:05 PM   #2
Ridgerunner3's Avatar
2002 25' Safari
Fountain Inn , South Carolina
Images: 11
Do you have the black framed Hehr windows? That is the type on my 02Safari. Mine will sometimes bind when opening & closing.
Bud
Ridgerunner3 is offline   Reply With Quote
Old 04-04-2012, 07:14 PM   #3
tinbender's Avatar
2001 16' Bambi
2013 23' International
Piedmont Region , North Carolina
Creation Windows -- Been there
Happy-rver,
I have a 2001 Bambi and it had windows that were made by a company called "Creation". The name was on the window. This company is indeed out of business. I looked for seals to maintain the windows for almost 3 years to no avail. They leaked like crazy, didn't open or close well, and I used every trick I could come up with to put off the inevitable, replacing the windows.
Don't want to be the bearer of bad news but after hitting many dead ends I ended up replacing the rear and front window on my Bambi. I don't have wrap arounds so they are the black type. I only have one small window on each side of the trailer and plan to replace those later this year.
If you intend to keep your trailer this is what I would recommend for you as well, even though I understand about how expensive it will be. I installed Hehr windows and they are a much better quality window than the original ones and I'm glad to say that neither of them leak!! Also my new ones have the same type seal around all the glass and the old ones used 2 different seals. Better all way around.
Probably not what you wanted to hear but now that it's over I'm really happy with mine.
TB
tinbender is offline   Reply With Quote
Old 04-04-2012, 07:36 PM   #4
2006 28' Classic
Ancaster , Ontario
The frames are black and only the bottom 1/3 open. I do not know the name of the manufacture.
Old 04-04-2012, 08:25 PM   #5
CanoeStream's Avatar
St. Cloud , Minnesota
Sounds like Hehr. Have you lubed hinges & the opening mechanism? I'd suggest DuPont Teflon Multi-purpose Dry Lube from Lowes.
5 meter Langford Nahanni
Old 04-05-2012, 07:26 AM   #6
tinbender's Avatar
2001 16' Bambi
Creation Logo
Happy-rver don't know if this will help but here ya go.
The logo is printed on the bottom right corner of the fixed glass on the big window and on my small ones it is on the bottom right hand corner of the opening part.
ID:	155069   Click image for larger version
Old 04-05-2012, 07:43 AM   #7
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
Ah, so this means that not all windows of that style are made equal nor are they the same brand. Take note. Hehr is still in business. It is good to hear that you got your issue resolved positively.
Old 04-05-2012, 09:57 AM   #8
2006 28' Classic
Ancaster , Ontario
Right you are, the logo is there and the brand is "Creation". It sounds like they are out of business, so I guess parts are no longer available.
Old 04-23-2012, 06:51 PM   #9
robert claus's Avatar
2000 19' Bambi
mt. Prospect , Illinois
I have the same Creation windows in my 2000 Bambi. The gaskets for the opening segments, and for the rear emergency window, were shrinking and pulling out of the frames, and they didn't seal anymore. I ordered new gaskets from the closest Airstream dealer last year. They gave me a length of self adhesive gasket, which is D shaped. It looks just like the gasket that goes around the perimeter of the door, but it is smaller. It is what the factory said is the replacement for the original, since that is no longer available. I stripped the original gaskets where the opening segments make contact, right down to the metal frame and wiped them clean. Fitting the new gasket, by adhering it to the vertical surface of the window channel where the glass makes contact, was quick and easy. The results were a dramatic improvement. This, combined with lubricating the mechanism, may resolve your problems for a long time.
robert claus is offline   Reply With Quote
Old 11-02-2013, 05:54 PM   #10
Soyboy's Avatar
1999 28' Excella
Frederick , Maryland
Images: 44
Just as a follow up in case anyone is searching "Creation Parts" etc. A company named Parkin purchased the existing Creation windows and parts when they went out of business. You may be able to find parts on their website.
1999 28' Safari
2012 F150 Platinum Max Tow 7650 GVWR 3.73 Elec. Locking Diff.(Prev 2003 Dmax).
Honda EU2000i, Equalizer Hitch
AM Solar Panels 150W - 2 Trojan T 105 6V Batteries
TAC MD-6
AIR 4534
On internet forums, please research and separate the wheat from the chaff (including mine!)
Soyboy is offline   Reply With Quote
Old 07-16-2015, 12:12 PM   #11
Uncle Shelly
Gshellhammer's Avatar
2001 25' Safari
Lakeview , Ohio
I had a difficult time finding visual guides for the gasket replacement of the creation windows. So I decided to create a reply to this topic to help others as they work on their Airstream.
Yes, you can identify the creation windows by there insignia in the lower right corner of the movable window. You can see the logo in front of my hand.
Name:   ImageUploadedByAirstream Forums1437066364.295955.jpg
You can also see that the original gasket has shrunk and has pulled away from the corners. Here's another picture.
Name:   ImageUploadedByAirstream Forums1437066940.576569.jpg
To get to the old gasket and clean off all surfaces, it is easiest to remove the window that moves. This can easily be accomplished by removing the lock washers from both sides of the down arms.
Name:   ImageUploadedByAirstream Forums1437067251.465205.jpg
Name:   ImageUploadedByAirstream Forums1437067282.286872.jpg
Now the down arm can be disengaged and the movable window can be swung up to A horizontal position and slid out.
Name:   ImageUploadedByAirstream Forums1437067514.703047.jpg
The offending gasket can now be pried out or pulled out. My windows had an additional flat gasket that was applied next to The original gasket. I have no idea where that came from.
Name:   ImageUploadedByAirstream Forums1437067770.064458.jpg
Once the gaskets had been removed, all services must be cleaned completely. I scraped with a flat bladed screwdriver and cleaned and scrubbed with isopropyl alcohol. I was able to clean and reapply gaskets on all four side windows in one morning.
Name:   ImageUploadedByAirstream Forums1437068086.463439.jpg
The gasket material I used came from airstream at Jackson Center. It is a D type open cell foam rubber, 1/2" on the adhesive side and 3/8" high.
Name:   ImageUploadedByAirstream Forums1437068610.111646.jpg
There is a channel at the top of the window opening.
Name:   ImageUploadedByAirstream Forums1437068796.174786.jpg
I decided to fill this channel also with the "D" gasket. I have a diagram of the window removal process in an Excella owners manual. It shows a "D" gasket there.
I did not replace the old gasket. I simply placed the new gasket all around. Once it was in place I rolled it down to ensure adhesion.
Name:   ImageUploadedByAirstream Forums1437070205.281326.jpg
I appear to be out of space. If possible I will continue in another reply.
Gshellhammer is offline   Reply With Quote
Old 07-16-2015, 12:31 PM   #12
Uncle Shelly
2001 25' Safari
Lakeview , Ohio
This is part 2.
The new gasket has been placed all around the window.
Name:   ImageUploadedByAirstream Forums1437070695.383993.jpg
Name:   ImageUploadedByAirstream Forums1437070718.322131.jpg
Name:   ImageUploadedByAirstream Forums1437070788.035049.jpg
Now I cranked the window down to make contact on the gasket. The gasket is not to be flattened, but just to make contact. Word of warning. After replacing the window in its tracks, make sure it is centered. It is possible to leave it slightly out and complete closure will not happen and could cause breakage.
Name:   ImageUploadedByAirstream Forums1437071020.092448.jpg
Name:   ImageUploadedByAirstream Forums1437071125.294130.jpg
I left the window closed for a period of time overnight so the gasket would adhere completely.
I am pleased with the result. Although my windows did not leak, it would only be a matter of time.
I am not a professional restorer. If you noticed a mistake please let us know through the forum.
Photos of Safari 1954 restoration safari 1954 1954 Safari 81 08-14-2012 06:01 PM
TX Veteran Designation on Drivers License Bluto Off Topic Forum 43 06-27-2012 12:31 AM
Equal-i-zer + add on sway control? NewbieAndy Hitches, Couplers & Balls 23 04-22-2012 11:44 AM
Looking for advice on possible purchase chiefbrody 1975 Overlander 12 04-09-2012 08:12 PM
Just bought 25' Safari jdanielii General Repair Forum 15 04-07-2012 07:27 AM
