03-07-2015, 06:28 AM
2013 30' Flying Cloud
Cincinnati
, Ohio
Window Popper gadget
Has anyone purchased the "Window Popper" gadget advertised in this month's issue of Airstream Life? website is "seeyoudowntheroad.com"
What a great idea and what appears to be an elegant solution. Much better than trudging out in my slippers to open a stuck window.
If anyone has tried the Window Poppers, any thoughts on how well they work, how easy they are to install, etc. would be greatly appreciated.
03-07-2015, 06:31 AM
Sneedville
, Tennessee
I have a set, but have not installed them yet. I hope to get out there today.
03-07-2015, 07:33 AM
2020 28' Flying Cloud
Upper St Clair
, Pennsylvania
I use silicone once a year, have not had any issues opening windows on three AS.
2020 28' Twin Flying Cloud
2021 F350 6.7 King Ranch
USAF Master Training Instructor (TI) & (MTI)- 68-72
Volunteer K9 Rehabilitator & Trainer
03-07-2015, 07:38 AM
Cincinnati
, Ohio
Thanks, let us know how it goes. Website says installation takes 5 minutes per window. Wonder what takes 5 minutes. Take a pic or 2 and post them if you can. Thanks
03-07-2015, 07:45 AM
Cincinnati
, Ohio
yes, I have tried that. I rub that 303 protectant on that I bought in Jackson Center on in Spring. Then 2 days later (OK, I am exaggerating here) the window is stuck and I try really hard to not "force" it with the interior handles so as to not bend/break them. Finally I walk outside, and sometimes all it takes is a mere pull with a fingernail (exaggerating again) to pop the window open.
So I am ready to try a Window Popper....in addition to applying the 303 protecant to the window seals to keep them in proper working condition.
03-07-2015, 07:49 AM
1976 31' Sovereign
Missouri City
Don Hardman
1976 31' Sovereign
03-07-2015, 08:25 AM
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
I have tried an alternative to this little device. I have drilled a 7/32" hole at the bottom center of the window/screen frame. I use a small wooden dowel to break the seal ion the window. It then opens readily with the interior handles. This seems to work well without anything sticking out in the way of the shade.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
03-07-2015, 08:26 AM
Sneedville
, Tennessee
Once the windows were freed and opened, it was a pretty painless operation. I didn't have any help on the inside and that would have made things go better. Of course, my windows are now unstuck so I won't be able to test the effectiveness of these devices. Here's some eye candy:
03-07-2015, 08:52 AM
Sneedville
, Tennessee
Yep, some are using wooden dowels that are not permanently mounted. Whatever floats your boat.
03-07-2015, 09:29 AM
2012 25' FB Eddie Bauer
Fairbanks
, Alaska
If your using 303 on the window gaskets I believe your using the wrong product to prevent sticking. It is primarily a UV protection. We use plain old silicone spray from NAPA once a year and have no sticking.
Rick
"When you find yourself in a hole - quit digging!"
2012 1/2 Eddie Bauer, 2016 Ram Laramie 3500 SWB 4x4 6.7L Cummins 68RFE
03-07-2015, 10:17 AM
Cincinnati
, Ohio
Thanks Mr. Prez. What size drill bit did you use? It must have been something to take a drill to your window frame. Was the screen frame or whatever you call the area where you drilled the hole "soft" or "hard" - meaning how long did it take the drill to go through? I have drilled on sheet metal on my truck when installing things and what I thought should be a 5 or 10 second drilling took a lot longer and required more push that I expected. Wonder what to expect from the Airstream window frame.
Thanks for sharing your pics and experience. I love adding another "project" to the Airstream list!
03-07-2015, 10:32 AM
Sneedville
, Tennessee
3/16 drill bit. The window frame seemed harder than the screen. The only bit I had was a step drill with 3/16 as the first part. Having someone on the inside pressing on the screen would make the process go quicker. I installed 5 poppers in about 30 minutes including getting the windows open. I also used a punch to mark where I wanted to drill.
07-05-2019, 04:05 PM
2018 25' Flying Cloud
McMinnville
, Oregon
I just installed them on our 2018 25 " FC FBT. Very simple and easy installation (no more than 5 minutes per window) and work as advertised. The seller is very easy to work with.
07-06-2019, 05:39 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Dielectric grease...
11-22-2020, 03:12 PM
2018 30' Classic
Williamsburg
, VA
I wanted to get these however the wife is concerned it would look bad. Amy thoughts or pictures would help. Right now I just go outside and use a plastic pry tool.
2018 Classic 30
2012 F250 6.7l
US Army Watercraft Engineering Officer
11-22-2020, 06:20 PM
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington
, Ontario
I have installed the window poppers and they work great. They look like original equipment and are well made. Although the supplier indicates that one per window is sufficient, I installed two per window for a better pushing balance. Sometimes handy when the windows have been closed for a long time and become a bit sticky. Very pleased with the purchase..
11-23-2020, 09:15 AM
McMinnville
, Oregon
They look fine and work very well see pics at:
https://seeyoudowntheroad.com/pages/window-poppers
06-02-2022, 12:49 PM
R.U.N.N.O.F.T.
2019 27' Globetrotter
Bethesda
, Maryland
Wife says these are a game changer!
Installed window poppers two months or so ago. One on square windows, two on either side of the larger end windows. These do not interfere with curtains or shades, as they don’t stick out any further than the existing window latches. Probably good to still take good care of the rubber gaskets, but not cause you can’t open the windows. Two kits did the 27FBQ. Work beautifully. High quality, and you can get parts if things get lost. I’m happy, wife is VERY happy! Nuff Said!!!
06-02-2022, 02:23 PM
Tavares
FWIW Airstream specifies Aerospace 303 on the window gaskets. Page 8-15 of my Owner's Manual, attached. I'm sure plain old Silicone spray would work as well. I also have used an old German car product called "Gummi Pflege Stift" (My German is a little rusty but I believe this translates to "Rubber Care Stick"), but don't have any of that around anymore.
If I need to, I use the "Credit Card" method to free the windows from the outside, but do apply some A303 from time to time as well, so don't have to do that very often.
“Character is doing the right thing when nobody’s looking. There are too many people who think that the only thing that’s right is to get by, and the only thing that’s wrong is to get caught.” - J.C. Watts Jr.
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
